jdm climate control help
Old Apr 2, 2007 | 02:13 PM
eg6T's Avatar
Default jdm climate control help
first ill start with everyhitng is jdm,wiring,front end,everything.
so i hook up the jdm climate control and it breaks the 7.5 fuse,nothing works...i put in a 10 fuse and it breaks that one as well.i put in a 15 fuse,it works for a couple seconds and then stops,fuse broke.i then put in a 25 fuse and the lights work but i cannot adjust the air,the air just stays on. i didnt have any more fuses so thats where i stopped.
anyone have any ideas or know why i can adjust the air?
Old Apr 2, 2007 | 02:29 PM
JDM-EJ1's Avatar
Default Re: jdm climate control help (eg6T)
Slow down cowpolk. What kind of car do you have? Is your car a DIRECT import from Japan? If not, did you rewire EVERYTHING with a JDM harness?
Old Apr 2, 2007 | 02:35 PM
eg6T's Avatar
Default Re: jdm climate control help (JDM-EJ1)
EVERYTHING is re wired with a jdm harness-everything is jdm
its an eg hatch
Old Apr 2, 2007 | 02:45 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">EVERYTHING is re wired with a jdm harness-everything is jdm
its an eg hatch</TD></TR></TABLE>
You have a short somewhere than, you need to find it and fix it. Something is causing the fuse to keep blowing.
Old Apr 2, 2007 | 07:31 PM
eg6T's Avatar
would that be somewhere in the wiring?
Old Apr 2, 2007 | 07:33 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">would that be somewhere in the wiring?</TD></TR></TABLE>
Yes. Did everything work fine with the USDM climate/wiring? If so, than it's a short/ground somewhere throughout the wiring system.
Old Apr 2, 2007 | 07:45 PM
eg6T's Avatar
yea..
should i try a 30 fuse and see what happens?
Old Apr 2, 2007 | 07:47 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">yea..
should i try a 30 fuse and see what happens?</TD></TR></TABLE>
No. You should only need to use the fuse that fuse box cover says. That will only bandaid the problem, you won't fix anything.
Old Apr 2, 2007 | 07:50 PM
eg6T's Avatar
ok ill replace it with another harness i have and check everything
Old Apr 2, 2007 | 07:53 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">ok ill replace it with another harness i have and check everything</TD></TR></TABLE>
I wouldn't do that at first. Check your existing harness first for any flaws.
Old Apr 2, 2007 | 07:54 PM
eg6T's Avatar
i did that and it looked fine...
Old Apr 2, 2007 | 08:01 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">i did that and it looked fine...</TD></TR></TABLE>
Did you check your grounds?
Old Apr 2, 2007 | 08:20 PM
eg6T's Avatar
yes they are fine
Old Apr 2, 2007 | 08:21 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">yes they are fine</TD></TR></TABLE>
Okay, what about the climate control itself? Would you by chance have another one you could swap out?
Old Apr 2, 2007 | 08:29 PM
eg6T's Avatar
yea i have 2...1 didnt work at all,got another and it works
Old Apr 2, 2007 | 08:30 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">yea i have 2...1 didnt work at all,got another and it works</TD></TR></TABLE>
What do you mean by didn't work? What didn't work on it?
Old Apr 2, 2007 | 09:23 PM
eg6T's Avatar
ok so i switch the harness out for the other one i had,and i also put back in a 7.5 fuse which should be in there.everything now works the same but i still cannot adjust the air,it just stays on.but it does not break the 7.5 fuse any more...
Old Apr 2, 2007 | 09:32 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">ok so i switch the harness out for the other one i had,and i also put back in a 7.5 fuse which should be in there.everything now works the same but i still cannot adjust the air,it just stays on.but it does not break the 7.5 fuse any more...</TD></TR></TABLE>
Since the JDM Climate uses the 'auto' feature, this could be part of the problem. But you said you had all the sensors, etc?
Old Apr 2, 2007 | 09:46 PM
eg6T's Avatar
yep all the sensors are in place
Old Apr 2, 2007 | 09:51 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">yep all the sensors are in place</TD></TR></TABLE>
No idea.
Old Apr 2, 2007 | 09:55 PM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
No idea.</TD></TR></TABLE>
+1 for trying.
I'd say take another look at you're harness. Make sure everything was pinned/soldered dead on. Mybae you missed something there.
Old Apr 2, 2007 | 10:36 PM
eg6T's Avatar
Default Re: jdm climate control help (ek forever guy)
yea thannks for the help
but i didnt ever touch the harness,they are factory
Old Apr 2, 2007 | 11:14 PM
dannis.'s Avatar
why cant people just do it like this. by the way this isnt me.
http://youtube.com/watch?v=d29rJzQqGYM
Old Apr 2, 2007 | 11:22 PM
eg6T's Avatar
Default Re: jdm climate control help (DannisEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DannisEG6 &raquo;</TD></TR><TR><TD CLASS="quote">why cant people just do it like this. by the way this isnt me.
http://youtube.com/watch?v=d29rJzQqGYM</TD></TR></TABLE>
because my car is rhd...so i swapped everything to jdm...
Old Apr 2, 2007 | 11:23 PM
dannis.'s Avatar
oh didnt know my bad.
