Oil leaking by headgasket?
There's some oil on the left side, i guess under the vtec solenoid. What could it be? I'm about to retorque my head studs cuz I haven't done it yet since I installed them new. Could that be why? It's only on that side and it's barley any.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg »</TD></TR><TR><TD CLASS="quote">mine leaks a little from there too. cam seals i believe</TD></TR></TABLE>
so there's only one? just this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owner »</TD></TR><TR><TD CLASS="quote">
the other seal is the dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee »</TD></TR><TR><TD CLASS="quote">
hahah. ill see if i can find an aftermarket one for cheap if not ill get an oem one
</TD></TR></TABLE>hahah. ill see if i can find an aftermarket one for cheap if not ill get an oem one
could be the cam seal, get a new aftermarket one with 2 o-rings.
then if u wanna make sure it wont leak then get a new vtec solenoid seal and it should be sealed after that... if not, then you could have a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xpsonic »</TD></TR><TR><TD CLASS="quote">could be the cam seal, get a new aftermarket one with 2 o-rings.
then if u wanna make sure it wont leak then get a new vtec solenoid seal and it should be sealed after that... if not, then you could have a problem.</TD></TR></TABLE>
im going to the the ac AUTOTECHNIC cam seal, i thinkit has 3-orings. its only $15
im going to the the ac AUTOTECHNIC cam seal, i thinkit has 3-orings. its only $15</TD></TR></TABLE>
is it me or does that sound like ebay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRobert »</TD></TR><TR><TD CLASS="quote">
i guess kenny tran used to run ebay parts (ac AUTOTECHNIC) on his old race car hatch then...lol
</TD></TR></TABLE>i guess kenny tran used to run ebay parts (ac AUTOTECHNIC) on his old race car hatch then...lol
I had the same issue, thought it was the cam plug, and it turned out to be the solenoid gasket. I pulled the solenoid off and cleaned up the gasket and surrounding metal. Used some RTV, and no more leaks. give that a try
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16gs »</TD></TR><TR><TD CLASS="quote">I had the same issue, thought it was the cam plug, and it turned out to be the solenoid gasket. I pulled the solenoid off and cleaned up the gasket and surrounding metal. Used some RTV, and no more leaks. give that a try</TD></TR></TABLE>
do they sell the vtec solenoid gasket iteself? i havent pulled it off the check yet. need to clean the soilenoid anyways so ill check it out when i replace the cam seal, retorque the headstuds and all the valve cover gaskets.
JDMisGOOD
12
Nov 12, 2005 09:54 PM
Austin
Jul 26, 2005 08:14 PM
TO ME! holla
