Air/heat not working
Old Apr 2, 2007 | 11:52 AM
andlude's Avatar
Default Air/heat not working
A couple of days ago I went to turn on the fan (not the AC) just to get some air moving, and it worked fine but i noticed when I turned it on a whole bunch of water came out from under may dash on the passenger side, so I just turned it off and it stopped. Today i went to go turn it on and nothing happens, no air comes out. Does anyone know what this could be? thanks
Old Apr 2, 2007 | 02:43 PM
Sam92Teg's Avatar
Default Re: Air/heat not working (andlude)
You had water in your blower motor, now it either blew a fuse or the bearing is seized.
Old Apr 2, 2007 | 02:54 PM
andlude's Avatar
Default Re: Air/heat not working (Sam92Teg)
hummm really? do you know how this could have happened?
Old Apr 2, 2007 | 06:43 PM
Sam92Teg's Avatar
You mean why your blower motor shot out water, and where did it come from? One of two reasons, water entering in from the outside, possibly thru the cowling or sunroof drain, or condensation from your A/C evaporator which hasn't drained properly thru the drain hose.
First try to find the reason water is in the blower motor, and fix the problem. Then try to spray some PB blaster into the motor via the air vent hose at the base of the motor. It should unlock the bearing if that is why it stopped working. Worked for me anyway, when I had the exact same problem. My leak was from the cowl, and then later, a bug made a nest in the evaporator drain hose under the car.
Modified by Sam92Teg at 7:53 PM 4/2/2007
EteBoy
Aug 11, 2010 10:17 AM
queda
15
Dec 16, 2009 12:56 PM
HondaAccordTdR
Aug 31, 2008 02:51 PM
Revolver123
Honda Civic (2001 - 2005)
Jun 14, 2008 05:01 PM
Adampops
Jan 4, 2003 05:48 PM
