i just blew up my civic...i need help
Old May 26, 2002 | 05:20 AM
6pucker's Avatar
Default i just blew up my civic...i need help
i blew my bottom end on my 99 si. i went to a local shop and was told that i could use the old jdm b16's bottom end. so i went out and bought a b16. i only needed the bottom so i took off the head and put it aside. after getting to the block and pulling my block out of the chassis, i compared them. they have different hoses and plugs(i expected a few slight changes but not like this). i was wondering if any of you done this kinda motor mix match? any help will be appreciated.
thanks in advance
[Modified by 6pucker, 2:21 PM 5/26/2002]
Old May 26, 2002 | 05:36 AM
CRX_VTEC's Avatar
Default Re: i just blew up my civic...i need help (6pucker)
what year B16 block did you buy??
Old May 26, 2002 | 05:38 AM
jdmjunkie's Avatar
what year block did you get? if it's a first gen you'll need to swap the thermostat housing. which hoses are you having trouble with? I'm not sure but if your block has a crank angle sensor you'll need to change out the oil pump housing/gear. I drive a EH so I'm not too sure which years use the crank angle sensor maybe one of the guys can help answer that?? also don't be worried about wiring on the block besides the possibility of the crank angle sensor swap all the required sensors or normal operation are there.
Old May 26, 2002 | 05:43 AM
6pucker's Avatar
Default Re: i just blew up my civic...i need help (jdmjunkie)
i bought a b16a1. i think its the very first b16's that came out. so all i have to do is change out the thermostat? thats what i was worried about... on the older b16 there's hoses on the pipe thats connects to the thermostat housing. i thought that i was going to have to pull out that pipe that runs behind the block. i dont have to do i? is there anything else i should know about other then the crank angle sensor? thanks for the replies guys!
thanks again
6pucker
Old May 26, 2002 | 05:48 AM
jdmjunkie's Avatar
nah that's it.. just change out the housing and thermostat. does your 99 block have a crank angle sensor?
Old May 26, 2002 | 05:50 AM
biggdogg's Avatar
you sjould swap your stuff to it because it`s gotta factory oil cooler on the back of the 1st gens wished i still kept mine . i gotta 2nd gen now 170 hp
Old May 26, 2002 | 06:57 AM
SCsol's Avatar
Default Re: i just blew up my civic...i need help (biggdogg)
rember to remove your oil pump on your 00 SI motor
just keep the blowen motor you will need every part but rember to swap oil pumps there is a crank sensor on the 00 SI you need
Old May 26, 2002 | 07:12 AM
6pucker's Avatar
Default Re: i just blew up my civic...i need help (lowsol)
yea it does have a crank angle sensor. do i really have to swap the oil pump?
anything else?
thanks guys
6pucker
Old May 26, 2002 | 10:42 PM
jdmjunkie's Avatar
anything else?
thanks guys
6pucker
yep you do
F20b_Integra
Jul 16, 2011 06:47 PM
gsr_porter
Oct 9, 2009 10:52 AM
EKHB
Feb 14, 2007 11:04 PM
matt c
Nov 9, 2006 03:00 PM
MugenSi00
Feb 24, 2002 09:20 PM
