90 degree anti-fouler fitting...
Anyone know where to purchase a 90 degree anti-fouler fitting to bolt into an 02 sensor bung. This is for clearance puproses.
Thanks!
Thanks!
I doubt they exist, since such a design would not work properly for the devices actual intended purpose. You'll most likely need to fabricate something, or locate a different fitting that can perform the same role.
FYI - I just found that vibrant performance sells a J shaped weld-on version....a Bolt-on version would be awesome!
