Car won't turn over
Old Apr 2, 2007 | 06:14 AM
93SiPrelude's Avatar
Default Car won't turn over
This morning my car was making a weird clicking noise from under the dashboard which i believe is the starter relay switch. It started but kept on making the noises so i went back home and parked it. Two hours later I went bak home nad my car wouldn't even turn over. Any suggestions?????????
Old Apr 2, 2007 | 07:34 AM
prelude1897's Avatar
Default Re: Car won't turn over (93SiPrelude)
might wanna check your starter to be sure it's still good. If that checks out, then it could possibly be your ignition relay
Old Apr 2, 2007 | 08:14 AM
Jagan'92's Avatar
potentially the main relay, especially that sound.
solder joints go bad when it heats up. you can pull it and heat up the solder points.
https://honda-tech.com/zerothread?id=1729919
or search prelude archives
Rcapalungan
Dec 30, 2013 09:49 PM
keviiinnnnn
Jan 2, 2008 07:27 PM
kmccann1
35
Dec 28, 2004 08:52 PM
SpoonPL
May 8, 2002 11:25 AM
