? Has there EVER been a final drive change in b16a transmissions obd0-1-2>?
Need to double check on this....
Are ALL b16a trannys obd-0 & obd-1 & obd-2 have the same final drive ratio of 4.400?
Because I am using obd-2 shafts with a differential and final drive from a obd-1 transmission. I want to make sure it will work and sync up correctly.
The early cable Y-1 transmission came with a 4.2 Final (almost positive the EURO Y-2 has the same FD as well)...the rest of the B16 transmissions had the 4.4
