I need a crank for my DOHC ZC?
Does anyone have a good crank from a sohc zc, dohc zc,d16a6 or d16z6.? I need one of these if you got one email me. I bought a used zc with spun rod bearing.Newmansx4n@aol.com
make sure you get a crank with the same diameter front snout as the one in the ZC - there are 2 different cranks and you need one that the ZC timing belt gear for the crank will fit
91civichatch2571
Oct 20, 2004 09:04 PM
