SRS light on and FOG light switch wiring.
I could not find the 2pin service connector for a SH prelude. Service manual says close to the OBD II connector but there's nothing there. Anybody know where can i find it?
Also, my fog not working and still trying to troublehoot it. I have the JDM switch and the problem is I don't know which on of those wires is which. Is there a thread for this here that has some good wiring diagram explanation?
Last one is I tried to replace my fuel filter and it is really damn hard to loose it. I already took all the lines to get the pressure out. I dont know why 5th gen put fuel filter that hard. 4th gen has a good location and it's really easy to replace. Do I need to get this filter from the bottom or car needs to be lifted?
need input guys.. please
Take out the bulb for the SRS
And about the JDM Fog switch, oh the fifthgen's you have to put it on the dim/sunroof/cruise switches, you gotta take the dimmer out by this I mean push it in or out which ever way it comes loose and connect the jdm switch where the dimmer used to go, the switch should be prewired so its plug and play, but you most likely need a relay aswell...search and you will find the info if not someone will help you out.
Good luck.
Good luck.
1slowcrx
Nov 9, 2011 12:41 PM
1329itr00
Jan 11, 2005 06:52 AM
