Stupid question, dropped block any damage could have resulted?
i was moving my block out from my room and accidently dropped it about 8 or so inches from the ground, could any damage result from that? its all together and assembled and whatnot
Unless it was concrete, I'd expect there to be more damage to the floor.
Unless it hit directly on an edge, I don't think you'll have any problems. Motors have to go through heavy abuse with solid mounts, and they pass those tests with flying colors. All I could see happening is denting the oil pan [and bending the oil pickup] or breaking a sensor off.
it actually fell on my kitchen floor its like vinal or however you spell it i think, like lamanit floor.
what do you mean by tuned? like spec or ems wise?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch »</TD></TR><TR><TD CLASS="quote">the block was never ran its fresh</TD></TR></TABLE>
lol
I was just messing with you.
lol
You should be fine, pull the pan to make sure it's not dented and to ensure the pickup is in good condition. Everything else should be fine, except your leg that is. lol
my oil pan wasnt damaged its the moroso drag oil pan, not a scratch or dent in it. lol
and you are right my leg is probably the only thing that sustained any damage, its a geed thing my leg wasnt pressed more firmly against the block when it fell or i would have been in deep ****
