best tranny for a D-block?
Old Apr 1, 2007 | 07:33 PM
HondaHeddie's Avatar
Default best tranny for a D-block?
My engine is fine so dont give me advice on swapping to another engine to get a better tranny please.
what is the best tranny for a Dblock
My orig tranny is dying and I plan to buy a junk one and rebuild it now while I can still drive to get parts. then I will swap the new one in.
so what is the best tranny for me to grab for this
Old Apr 1, 2007 | 07:37 PM
Redline130's Avatar
Default Re: best tranny for a D-block? (HondaHeddie)
An Si one would probably be the best overall choice. Should be much easier to find than a ZC tranny and I'm guessing that you don't want to go through the hassle of converting to hydraulic.
Old Apr 1, 2007 | 07:39 PM
crooked muffler's Avatar
Default Re: best tranny for a D-block? (Redline130)
Si w/ zc 3-4
Old Apr 1, 2007 | 07:44 PM
Default Re: best tranny for a D-block? (crooked muffler)
I dont want hydro you're right.
I drive long distances alot so I want to have the long top
I want to go LSD as well if possible
since I am planning to open it up and replace stuff the option of custom mixes is available too
so I suppose the best question is
what is the best LSD capable tranny to rebuild for a D-block in a daily driver?
Old Apr 1, 2007 | 09:11 PM
Redline130's Avatar
You could get a Quaife and put it in a Si or ZC tranny, along with replacing the synchros, bearings, and seals and have a pretty durable tranny. Or if you are on a budget, you could go with an OBX LSD. I believe there are ZC trannys with LSD's too, but they are kinda rare.
Old Apr 1, 2007 | 09:23 PM
SIred91's Avatar
Rainman
Si with the HF fifth gear, quaife LSD....../thread.
Old Apr 1, 2007 | 09:28 PM
nihad's Avatar
Default Re: best tranny for a D-block? (SIred91)
now that would not be bad a dx tranny is fine or si and the hf 5th gear would be nice. FOr more fuel effficent ride.
Old Apr 1, 2007 | 10:59 PM
4 door love's Avatar
Default Re: best tranny for a D-block? (nihad)
I did the si tranny swap in my 90 LX and i love it other than at 70mph i am at about 3500rpm
Old Apr 2, 2007 | 02:42 AM
BlueCrxNC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Si with the HF fifth gear, quaife LSD....../thread.</TD></TR></TABLE>
Well, you could do better with more OEM parts...
DOHC ZC 3rd & 4th and JDM Integra ZXi Final of 4.437 and mate all that with the LSD of your choice.
For the newb's:
DX, Si and Teg ZXi all have the same gearing 1-5. Only differences are Final Drives which make a hell of a difference. (3.88, 4.25, and 4.4375 respectively)
Old Apr 4, 2007 | 04:43 PM
Default Re: best tranny for a D-block? (BlueCrxNC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">
For the newb's:
DX, Si and Teg ZXi all have the same gearing 1-5. Only differences are Final Drives which make a hell of a difference. (3.88, 4.25, and 4.4375 respectively)</TD></TR></TABLE>
r u sure?
what about transzex's swap
si w/ zc 3-4 gears?
OK Im not sure for EF cable... heres info for 92-95s http://home.cinci.rr.com/mistab0ne/tranny.html
Old Apr 4, 2007 | 04:58 PM
BlueCrxNC's Avatar
That's what I meant. DX/Si/ZXi 1 & 2 (Implied from "Si with the HF fifth gear, quaife LSD....../thread"); with ZC 3 & 4; HF 5; ZXi Final
See my Sig for my Tranny setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crooked muffler &raquo;</TD></TR><TR><TD CLASS="quote">
r u sure?
si w/ zc 3-4 gears?
mykoeg6
Transmission & Drivetrain
Oct 15, 2014 08:17 PM
TommyBB
Oct 4, 2005 09:05 PM
functionFiRst
Apr 16, 2002 12:16 AM
