camber "washer trick" affect ability to adjust toe?
Old Apr 1, 2007 | 07:21 PM
tx6stringer's Avatar
Default camber "washer trick" affect ability to adjust toe?
My 2000 Civic has been lowered and im gettin some uneven tire wear in the rear. Im planning on doing the washer trick to level out my tires but I have heard people say that shops cannot get the toe exact after doing this. does anyone know if doing the washer trick will affect a shop's ability to set the toe to exactly 0 degrees. If not, should I take this route?
Old Apr 1, 2007 | 07:56 PM
kaiba's Avatar
Default Re: camber "washer trick" affect ability to adjust toe? (tx6stringer)
If the shop can't do that then they don't know to to do aligment.
Old Apr 1, 2007 | 08:16 PM
1995Civic's Avatar
Default Re: camber "washer trick" affect ability to adjust toe? (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">If the shop can't do that then they don't know to to do aligment.</TD></TR></TABLE>
I agree.
I did the washer trick on my 95 ex, and when i had my alignment done the toe was adjusted perfectly I physically watched it being done, so i know its possible.
to bad alignment shops
Old Apr 2, 2007 | 08:17 PM
Default Re: camber "washer trick" affect ability to adjust toe? (1995Civic)
sounds good. im gonna jump on that. appreciate it.
Old Jun 2, 2007 | 10:50 PM
hoskos's Avatar
sorry for the noob question...
but how exactly is it done? my alignment shops here told me to get a adjustable toe kit instead
Old Jun 2, 2007 | 10:53 PM
allricedout's Avatar
dont cheap out and just ante up on a camber kit... less of a headache and fully adj.
mark2583
Jul 31, 2007 04:07 AM
Devious951
Apr 22, 2007 06:30 PM
Flava
Suspension & Brakes
26
Jun 9, 2006 08:56 AM
wreckedmyteg
Oct 5, 2005 07:50 PM
CivicSiRacer
May 12, 2003 03:18 AM
