Raising compression = how much horsepower?
I think it really depends on your cams. Some cams will take advantage of it and some won't. If you're just raising your compression with ITR pistons and not changing anything else, i'd say you wouldn't even notice it.
Sticka, WAssup ?
Acutally, I think it was every point raised in compression was 2-4% gain.
yeah i think that is what i meant
as you go up in comp pressure you go up in heat, you get dimminishing returns after a point, and once you reach a point you start detonating, and you have to retard timing, working against your desire to gain HP. but just going up to ITR pistons shouldn't put you above the point of diminishing returns, although our engines are already very close (on regular pump gas) cams is a good idea to compliment this change, and also valve springs and retainers, and if you are going this far already, you might as well throw some sodium filled valves in there, they are lighter and if I remember correctly they don't heat up as bad (either that or they heat up more, quite crucial, and you should make sure before you do it).
VVENOM800TT
Feb 17, 2011 02:48 PM
mrduque
Apr 24, 2003 10:17 AM
