My Gas Sucks!!
Old Apr 1, 2007 | 06:48 PM
Topnotcheez's Avatar
Default My Gas Sucks!!
Wuzzup. Just wanted to get some recommendations on what I should do next. I've finally got my car (1995 Honda Accord Wagon) back on the road. Its been sitting in the driveway for over 2 years since I've been working on it. The motor is strong. I recently changed the sparks and Plugs (all OEM), but I still gettin like 14 mpg. Any suggestions?
Here's a pic of the work in progress.
Modified by Topnotcheez at 11:08 PM 4/1/2007
Old Apr 1, 2007 | 06:54 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: My Gas Sucks!! (Topnotcheez)
fixed your pictures
Old Apr 1, 2007 | 07:10 PM
Default Re: My Gas Sucks!! (TouringAccord)
Thanks!! ( I'm learning...this is my first time posting images as you can see.) Thanks again.
Old Apr 1, 2007 | 07:11 PM
H-T Order of Merit
no problem
https://honda-tech.com/zerothread?id=1913244
That is a thread where someone was trying to learn how to post pictures as well, see if that helps.
Old Apr 1, 2007 | 07:45 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">fixed your pictures </TD></TR></TABLE>
No you didn't.
Old Apr 2, 2007 | 02:05 AM
krytoi's Avatar
did u change the oil after it was sitting .clean ur fuil injector, change air filter,oil filter try that before doing anything else
Old Apr 2, 2007 | 02:37 AM
pos_cd5's Avatar
Default Re: (krytoi)
whats your method for determining your MPG?
Old Apr 2, 2007 | 02:50 AM
Yes I did. That was the first thing I did. I changed the oil, and filter. (also changed the air filter). I determined my mpg like so. (I got 260 miles on this tank of fuel. I recall my tank takes 18 gallons (95 Accord Wagon). 260 / 18= 14 mpg. I guess it wouldn't hurt to change it again. I did have the car sitting for two years. I'm still on my third tank of gas since I started running it again.
Old Apr 2, 2007 | 03:13 AM
H-T Order of Merit
Default Re: My Gas Sucks!! (02 accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">No you didn't.</TD></TR></TABLE>
Yes I did. They were working yesterday when I logged off, now they aren't. Don't worry, we'll get it worked out.
Old Apr 2, 2007 | 10:35 AM
hurleyint's Avatar
o2 sensor?
Old Apr 2, 2007 | 01:47 PM
krytoi's Avatar
i dont think u can fit 18 gallons in the tank =/ my accord takes about 10 tops
Old Apr 2, 2007 | 02:07 PM
BLKFLSH's Avatar
Default Re: (Topnotcheez)
You have to go by how much gas you burn (between fillups), and not what the tank holds. You didn't run the tank dry, did you? You are pencil whipping your mileage.
Old Apr 2, 2007 | 03:50 PM
fw190bvi's Avatar
Default Re: (BLKFLSH)
you have a 17 gallon tank.
light comes on at 14 gallons aka 3 gallons left.
Old Apr 2, 2007 | 04:18 PM
pos_cd5's Avatar
Default Re: (fw190bvi)
like stated above, correct way is to fill up your tank, drive it til its time to fill up again. fill up, and divide the miles you've driven by how much gas they are able to pump into your tank. it wont be 100% accurate but will be close enough.
Old Apr 3, 2007 | 03:25 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topnotcheez &raquo;</TD></TR><TR><TD CLASS="quote">... I recall my tank takes 18 gallons...</TD></TR></TABLE>Doesn't matter. Start with a full tank (zero the trip odometer). Then the amount of fuel that IT ACTUALLY TAKES to fill it back up is the amount you should use to calculate. The accuracy depends on how consistantly you fill the tank each time. If you use several CONSECUTIVE fill-ups, total miles and total gallons, it gets more & more accurate over a longer time.
jr22hockey
Mar 9, 2009 02:19 AM
jafriede
26
Jul 21, 2008 05:37 PM
92HB_HB
Jul 26, 2007 04:13 AM
ceddyced
Dec 29, 2005 09:07 AM
aeongap
Jul 25, 2005 07:41 PM
