K20a3 Fix!
Old Apr 1, 2007 | 06:48 PM
ep3drvr's Avatar
Default K20a3 Fix!
Does anyone know of a set or kit that i can buy, opposed to buying all the parts i would need to make it a typeR pistons, rods, cams, etc...
Old Apr 1, 2007 | 07:57 PM
Civic Hybrid's Avatar
Default Re: K20a3 Fix! (ep3drvr)
bump bump bump it up!
Old Apr 2, 2007 | 05:39 AM
Mugen Dom's Avatar
A K20A from anywhere
Old Apr 2, 2007 | 05:43 AM
2004CivicHBSi's Avatar
http://fitswap.org/
only info i know about engines/fits
Old Apr 2, 2007 | 06:19 AM
ep3drvr's Avatar
bump bump
Old Apr 2, 2007 | 09:13 AM
Mugen Dom's Avatar
Default Re: K20a3 Fix! (JdMK20Ahatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMK20Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">A K20A from anywhere</TD></TR></TABLE>
Old Apr 3, 2007 | 07:28 PM
ep3drvr's Avatar
bump bump bump!
Old Apr 3, 2007 | 07:30 PM
Aco512's Avatar
wouldn't it be easier buying the motor and tranny versus modifying your current motor into the 'a'
Old Apr 4, 2007 | 10:25 AM
ep3drvr's Avatar
Default Re: (Aco512)
It would be but i dont have 6000 for a swap! Where as if i just pulled it a part and put new parts in it will cost me way less than that and take me a weekend!
Old Apr 4, 2007 | 08:15 PM
Lucky-13's Avatar
Default Re: (ep3drvr)
odds are your not gonna find a wrecked type s....just get a head on here and build your block with some aftermarket and boost it
Old Apr 4, 2007 | 09:08 PM
ep3drvr's Avatar
Default Re: (youvgotmail)
No thanks the whole point is to not keep the stupid a3 block stock! GTFO! Stock A3 suck!
Old Apr 4, 2007 | 09:19 PM
Mugen Dom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ep3drvr &raquo;</TD></TR><TR><TD CLASS="quote">No thanks the whole point is to not keep the stupid a3 block stock! GTFO! Stock A3 suck!</TD></TR></TABLE>u want to get kicked off the board this would be a great way to start....
1. Your not gonna aquire a "kit" to build a typeR motor out of an A3 for cheap.
2. Buying all the parts to do what u want to do will cost more than 6Gs.
3. Why not do some research using the Search up top right of your screen before asking such questions.
Check out K20A.org tons of k series knowledge...you deffinately need it to you for being an ***
Old Apr 4, 2007 | 10:32 PM
Lucky-13's Avatar
Default Re: (JdMK20Ahatch)
hahaha
Old Apr 4, 2007 | 10:46 PM
ep3drvr's Avatar
You know what i know! Keep laughing "youvegotmail" keep punking ppl on honda-tech!
Old Apr 5, 2007 | 07:49 AM
eloist2's Avatar
the K20a3 cannot handle type r internals.
The block is much weaker.
About the only thing you can do with an A3 is put new cams in. If you want a built motor, buy a real motor.
Use your A3 as a back-up. It's pointless to do anything with it other than boost.
Old Apr 5, 2007 | 08:34 AM
WhiteOnRice's Avatar
Just get Skunk2 internals. You could probably see ~200 whp for $2000 plus tune.
Old Apr 5, 2007 | 02:15 PM
BarracksSi's Avatar
EPHatch member chunky has done a lot of stuff to his A3. But, the only important A3 part that's left is the block.
Lately, I've been finding out that some of the heavy-build motor guys are going with A3 blocks. They've usually got two reasons -- they're cheap, and their lack of under-piston oil squirters is actually a benefit at extra-high revs (10K+) because the pistons & rods stay lighter by not being drenched in oil.
Old Apr 5, 2007 | 10:23 PM
ep3drvr's Avatar
Default Re: (BarracksSi)
Just curious, Do you know about how much money would be spent on that, cuz im on a budget. I was just thinking about a k24 with type-s or r head work what would be better, money wise, a3 block or the k24 swap w/ head work.
Old Apr 6, 2007 | 03:45 AM
BarracksSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ep3drvr &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, Do you know about how much money would be spent on that, cuz im on a budget. </TD></TR></TABLE>
A lot.
Old Apr 6, 2007 | 07:57 AM
Go b00st
Old Apr 6, 2007 | 10:05 AM
eloist2's Avatar
get a TSX K24.
It already has the vtec head.
jDm_eDm
Feb 26, 2007 12:44 PM
StRoKeD-B16bEj2
Jul 15, 2006 08:56 PM
EF_9
Jun 19, 2006 09:39 PM
Type R #462
Nov 20, 2004 12:00 AM
Code Blue
Nov 25, 2003 10:21 AM
