A few questions about a gsr swap
1: If i run a p30 (sir-2) ecu on my gsr will it look for 2 o2 sensors any way to use just one, also i use a header for a b16 right?
2: when ordering a blox or skunk2 intake mani, i get one for a b16/itr or a gsr one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90zcCRX »</TD></TR><TR><TD CLASS="quote">1: If i run a p30 (sir-2) ecu on my gsr will it look for 2 o2 sensors any way to use just one, also i use a header for a b16 right?
2: when ordering a blox or skunk2 intake mani, i get one for a b16/itr or a gsr one</TD></TR></TABLE>1)if you are going to use a after market im get the aebs,blox or skunk2.2) no you can not use a b16 header you will need one for a b18 because the b16 have a shorter deck height.
i have a jdm gsr motor in my 90 ef hatch and i have a aebs im,ebay header and i'm using a chipped po6 converted to vtec with a gsr basemap.i hope this helps you with your questions.
for q#1 i cant help but for #2 if the gsr is 92-93 get a b16 r itr if its 94 or newer you need a gsr mani. as far as the o2sensor question if a p30 needs a second o2 just wire it in. i know a pr3 obdo uses 2 and i wired mine in, just make sure they are both in the wright spot and wired wright or the car wont run its best
vestalfootball72
Oct 26, 2006 08:27 AM
eddiecut
Nov 9, 2002 11:58 AM
