h22a 6th gen swap questions
Old Apr 1, 2007 | 04:51 PM
silvaccordex's Avatar
Default h22a 6th gen swap questions
I have a 2001 Accord and would like to do an OBD2 h22a4 swap. I know i will need a p13-a12 ecu from a 96 prelude and a obd2b-Obd2a Conversion harness. My questions were on the powersteering line and slave cylinder. Some have modified theres where some have said you can use the accord PS pump and bracket and it will work fine, is that true? Also, the slave cylinder and bracket from the accord? And does anybody make and DS mount bracket for the swap? What kinda wiring will i need to do for my OBD2 swap? I already have vtec. Any info would be great, thanks!
Old Apr 1, 2007 | 06:41 PM
Cronousman's Avatar
Default Re: h22a 6th gen swap questions (silvaccordex)
I actually would like to see this happening =P bump
Old Apr 1, 2007 | 06:49 PM
glamXXXrock's Avatar
correct me if I'm wrong, but I believe the P13 is an obd1 ecu
Old Apr 2, 2007 | 02:33 AM
DSRxRICKY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvaccordex &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2001 Accord and would like to do an OBD2 h22a4 swap. I know i will need a p13-a12 ecu from a 96 prelude and a obd2b-Obd2a Conversion harness. My questions were on the powersteering line and slave cylinder. Some have modified theres where some have said you can use the accord PS pump and bracket and it will work fine, is that true? Also, the slave cylinder and bracket from the accord? And does anybody make and DS mount bracket for the swap? What kinda wiring will i need to do for my OBD2 swap? I already have vtec. Any info would be great, thanks!</TD></TR></TABLE>
the PS lines or slave cyc didn't work for me, but i remember someone telling me the prelude ones will work. i didn't want to deal with it so i ditched the PS
Old Apr 12, 2007 | 02:24 PM
98Accord DOHC's Avatar
you guys checkout my archives. i did this swap 5 years ago and i'll tell you guys what you need to know except for the distributor rewiring because i forgot.
Michael Watson
Jan 9, 2016 01:55 PM
JDMAccord13
Dec 7, 2012 09:46 AM
Crxh22ajdm
Nov 7, 2012 04:01 PM
01sdime
Feb 2, 2012 11:04 AM
Sleeping4drLS
Feb 10, 2003 09:18 AM
