Suspension & Brakes Theory, alignment, spring rates....
Need Opinion on Suspension?
Old Apr 1, 2007 | 03:10 PM
girliehonda's Avatar
Default Need Opinion on Suspension?
Help my girlfriend decide on what suspension to go with for her weekend warrior EG. So far we narrow it down to lowering spring or coilover.
Heres out ideas.
Lower Springs- Tein , Eibach or H&R .
Coilover Sleeves- UGR or Omni Power Slip Over.
Budget is $250.. no more...
She plan to run 15' wheels on Drag Radial.. but she is worry about if she get lower spring the tires might rub and she wont be able to adjust it. How low can u go if you want to run 15' drag radial tires?
Plan is just a 1.5 inch. We dont want to ruin the Header too.
Well i hope you guys can help. Thanks for your time.
Old Apr 1, 2007 | 05:18 PM
Default Re: Need Opinion on Suspension? (girliehonda)
Anyone?
Old Apr 1, 2007 | 05:40 PM
flipsyde's Avatar
i say if its a girls car than just go with lowering springs. they seem to be much more stiffer than coilovers.
Old Apr 1, 2007 | 06:55 PM
Default Re: (flipsyde)
thanks for your reply but does anyone know if your running BFG Drag Radial 15' would it rub the fender? just from the pix on here in HT forum the side wall are pretty wide and if i used lower springs then i wouldnt be able to adjust it?
anyone else got any suggestions or want to share your set up with me?
[CG]
Suspension & Brakes
13
Jul 30, 2009 10:39 AM
JDM_Andrew
Suspension & Brakes
11
Mar 24, 2006 06:38 PM
97exd16
Suspension & Brakes
17
Aug 17, 2005 05:16 AM
umrex
Dec 3, 2003 09:21 AM
Turboteggy
May 9, 2003 09:26 AM
