JDM 93 H22A motor lags before vtec need help!!!
i hav a 96 accord and i have swaped in a jdm 93 H22A with the orgional computer and when im punching it the motor lags between 3000rpm and a bit after 5000rpm the only thing that i do not have hooked up are the 02 sensors. When i run my chiped p28 it works fine but i want to keep it stock cas the vtec scream louder n pulls harder then the p28 im thinkin that the p13 might blow my motor im not sure ijust dont like the lag need help!!!!!!!
So you put an obd1 engine in your obd2 car,do you have a conversion harness? Hooking up your o2 sensors is most likely a good place to start
. Without the primary o2 hooked up your ecu doesnt know the a/f and rather to enrichen or lean out thus.
I'm trying to be nice here. You have alot to learn
. Without the primary o2 hooked up your ecu doesnt know the a/f and rather to enrichen or lean out thus. I'm trying to be nice here. You have alot to learn
haha kool thanks i'll get right on that by any chance woud u know which wire is which onthe engine harness for example i have the 96 lx accord harness and the colors are like orage, green etc.......... i just need to kno which one is the heater ground etc..... because the harness i got for it came chopped up.
duceducecord
Apr 3, 2007 01:23 AM
96slammedh22
Dec 31, 2004 04:25 AM
