EG hood for K24A2 swap
Does anyone know of an aftermarket hood for for this swap? Maybe one of you have noticed that you're aftermarket hood has more heigth clearence than the stock hood. Thanks
I wasn't aware there was a special hood needed for this swap. Try the Hybrid forum. You'll get a better answer there.
The only swap I've ever heard of needing a different hood is the h22 with h22 tranny.
The H2b eliminates that I believe.
k24's are tall engines. almost 20mm taller than a k20 if i remember.
if all else fails you could try propping your hood up at the hinges
Wow, never would have thought two whole Centimeters would make that much difference.
If it's that miniscule, save yourself some money and just cowl the hood up.
