Another Oil question! About Mobil One 5w30.
Old May 25, 2002 | 08:45 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Another Oil question! About Mobil One 5w30.
A lot of people using Mobil One 5w30 have complained of having to add oil, some more than others. Could it be possible that the missing oil is all going through the PVC valve, because it's so thin, especially if you have I/H/E, because I've noticed more oil missing ever since I've done my I/H/E. If not where does it all go?
P.S. I do drive my car really hard every single day, but still 2 quarts every 3,000 miles is crazy.
[Modified by 01PYTypeR#1140, 12:47 AM 5/26/2002]
Old May 25, 2002 | 08:51 PM
dohcsideSi's Avatar
Default Re: Another Oil question! About Mobil One 5w30. (01PYTypeR#1140)
honda just released a bullentin on s2000 warrenty repairs stateing, that you must use 10w30 on all warrenty jobs.......esp on customer complaints of oil consumption....note to self use 10w30
Old May 25, 2002 | 09:08 PM
01-1293's Avatar
Default Re: Another Oil question! About Mobil One 5w30. (dohcsideSi)
so whats the deal........i don't know **** about oil........I was going to buy some 5w30 mobil 1 tommorrow........should i go with the 10w30??
Old May 25, 2002 | 09:35 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Another Oil question! About Mobil One 5w30. (01-1293)
no, buy 5w-30
Old May 26, 2002 | 06:13 PM
Old May 26, 2002 | 07:19 PM
JSIR's Avatar
New User
of course much of it does go through the pcv system, if you ever take off your intake manifold you will see a stream of oil coming out of the ends, you'd be surprised how much makes it to the intake manifold. Thinner oil also makes it past the rings a bit easier I think , it eventually all burns up regardless of the route it takes. A thicker oil normally burns off at a slower rate from what I have found. Doesn't have much to do with protecting the engine, just whether you mind putting in extra oil between changes. hth.
Joey
Coolero
20
Oct 18, 2009 07:44 PM
VINtegra90
Apr 18, 2005 03:00 PM
nudo wo0do
Nov 9, 2004 10:02 PM
V-Thang
Acura TL, RL & ZDX
Jan 9, 2004 11:04 AM
TypeR01-424
Aug 17, 2001 07:51 AM
