Question about using a externally wastegated T3 houseing on GT28r
Old Apr 1, 2007 | 05:38 AM
mrbigg9032's Avatar
Default Question about using a externally wastegated T3 houseing on GT28r
Im thinking of buying a GT28r turbo for pretty cheap, but i want to convert it to external wastegate. Is there a T3 exhaust housing that I can swap on or the only way i can convert it to external wastegate is weld up the flapper.
Old Apr 1, 2007 | 07:17 AM
Boilermaker1's Avatar
You should be able to use one of the T3 housings available for the GT28RS. The hot sides are the same, the RS has a little bigger compressor.
Old Apr 1, 2007 | 03:03 PM
mrbigg9032's Avatar
Bump for some more information
Old Apr 3, 2007 | 05:47 AM
mrbigg9032's Avatar
bump for more info
Old Apr 3, 2007 | 06:12 AM
LeGeND4LiFe's Avatar
Default Re: (mrbigg9032)
The GT28RS/GT2871R T3 turbine housing I have has a different turbine housing machining so it won't fit the GT28R.
You can try to see if ATP Turbo can machine one for you, for $250+. Probably not worth it, on only a GT28R.
sikid111
Sep 20, 2010 10:16 AM
manuel12
May 30, 2009 09:48 PM
mymeatb18"
Jun 22, 2007 12:29 PM
1.8T_EG
Oct 30, 2002 09:50 AM
