Camber Kit....
Need help on which one to buy. I have a 95 civic coupe but I changed the front brakes to the 94 gsr. So would I have to buy the 94 integra camber kit or would I still have to buy the 92-95 civic camber kit???
I have bought the skunk 2 front a arm kit for 2 of my hondas. I have had luck with them. They re designed bolts are better on the second set I just got, should resist slipping (a complaint I read about but did not experience). You will most likely need the civic one because the part where it bolts to the shock tower is probably the main thing you need to worry about, not the brakes. Unless the acura suspension parts you switched to get the brakes are way different?
Well when I changed it I changed the entire control arm/hub.... I know that the skunk 2 camber kit is connected way at the top so I was wondering if there is any difference in the civic and the integra kit. But from what i'm getting from your reply is that the 92-95 civic should work just fine.
