pics of my JDM ITR turbo and more from NZ (56k no)
First of all, i would like to say hi. been around honda-tech for ages but dont really post much, just read read read. no flaming please!!!
Ive had my 1996 JDM ITR for about 5 years now, about half a year ago it started life again forced induced. i finally got it tuned last month after trying for 4 dyno sessions
it made 370whp @ 15psi with a GT2871R .86, quite different to drive compared to being NA.
In NZ, most of our cars are JDM Imports, you guys might find our style of modifying cars is slightly different to in the US. i guess the reason is because like i said our cars are JDM in the first place
mods list:
ENGINE (block & head, ignition, fuel, extras)
9.3:1 CR
JE forged pistons
JE Proseal piston rings
Eagle H beam conrods
Modified Block guard
TAS adjustable cam gears
Magnetic sump plug
Fully balanced crank, pistons, rods, flywheel and crank pulley
MSD distributor cap and rotor
Speedfactor ignition coil
Spoon Sports sparkplug leads
Iriway iridium spark plugs (temp 8)
510cc injectors
Walbro 255 fuel pump
Sard Fuel pressure regulator
XRP fuel gauge
GM 3bar map sensor
Spec2 40mm aluminum radiator
Apexi radiator cap
Cusco Oil Catch Tank
Solid filled engine mounts
Mitsuboshi earth kit
Spoon Sports reservoir tank covers
Heat wrap
INTAKE, TURBO & EXHAUST
Apexi Air filter
Spec2 intake and intercooler pipes with Samco hoses
Garrett GT2871R ball bearing turbo
Racepro intercooler
Trust Type R blow off valve
Spoon Sports 70mm Throttle body
Gizzmo intake manifold gasket
Spec2 Stainless Ramhorn turbo manifold
Spec2 Downpipe
Spec2 3" Stainless exhaust system with Titanium muffler
Tial 38mm wastegate with Spec2 dump pipe
SUSPENSION & DRIVETRAIN
HKS Hipermax II suspension (F9,R7)
Cusco 6point roll cage
ITR Front Tower Bar
Cusco rear strut bar
Cusco Front Lower tie Bar
C pillar bar
Room bar
Exedy Daikin JDM 3puk clutch kit
Jspec 4kg chromolly flywheel
Jtune shift likage bushes
BRAKES & WHEELS
NSX front calipers
Legend rotors
Cusco master cylinder brace
Bendix ultimates brake pads- front and rear
15x7 gunmetal Rays Engineering TE37 w/ Toyo T1R tyres
Aluminum wheel nuts
INTERIOR
GReedy/Trust Profec B spec 2 boost controller with remote high boost
Apex-i Power FC
Defi exh, boost, oil and water temp gauges
Defi control unit II
Bride bucket seat
Recaro SRII seat
S2K start button
ITR Titanium gear ****
Vtec Light
EXTERIOR
Bellof HID headlights
Carbon Fiber AERO jap-spec Bonnet
Mugen front bumper - modified with ITR Front Grill
Mugen side skirts
98Spec rear bumper
Mugen carbon fiber Adjustable wing
Iyaero motorparts canards
PICS taken from(more pics in the link):
http://www.redlinetec.co.nz/fo...art=0
Modified by blackntegra at 10:53 PM 4/1/2007
mods list:
9.3:1 CR
JE forged pistons
Magnetic sump plug
510cc injectors
XRP fuel gauge
GM 3bar map sensor
Apexi radiator cap
Heat wrap
Apexi Air filter
Racepro intercooler
Spec2 Downpipe
ITR Front Tower Bar
C pillar bar
Room bar
BRAKES & WHEELS
NSX front calipers
Legend rotors
Aluminum wheel nuts
INTERIOR
Apex-i Power FC
Bride bucket seat
Recaro SRII seat
S2K start button
Vtec Light
EXTERIOR
Mugen side skirts
98Spec rear bumper
theres more pics on the redlinetec.com link
hey V14d, if your in Auckland, come to our drag day on the 20th april
what kind of air intake scoop is that on the from bumper of the "spoon" ITR? I would like to get my hands on something like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donz »</TD></TR><TR><TD CLASS="quote">what kind of air intake scoop is that on the from bumper of the "spoon" ITR? I would like to get my hands on something like that.</TD></TR></TABLE>
looks like a J's Racing air intake duct
very nice
I could really use a hood and front bumper set-up like that to dissipate some of the scorching heat under my hood..What are they if u don't mind me asking? Edit, my bad for not reading
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack »</TD></TR><TR><TD CLASS="quote">Tight collection of cars.</TD></TR></TABLE>
