Stalling when clutch depressed.
Old Mar 31, 2007 | 08:08 PM
Aquafina's Avatar
Default Stalling when clutch depressed.
Stock D16Y7 SMSP big tube header and race exhaust.
Adjusted valve lash about 2,500 miles ago, .001 tighter on IN/EX than factory specs. Starts up on the first crank and idles fine. I'll be cruising and clutch in and shift into neutral when coming to a stop and it will die. This isn't every time, but happens a couple times a day. Only CEL is from running one o2 sensor. Never had this problem before. Seems like it is getting worse every week.
Old Mar 31, 2007 | 09:08 PM
Combustion Contraption's Avatar
Have you pulled the codes again recently to make sure another code hasnt appeared? Every civic from that generation i have worked on that has the primary o2 sensor go bad has the exact same symptoms.
Old Apr 1, 2007 | 12:43 AM
Aquafina's Avatar
Default Re: (Combustion Contraption)
Nope. I'll check tomorrow after I rake my yard.
@ck
Jul 31, 2010 04:46 PM
ek-g6
Jan 30, 2008 10:19 PM
DBKIDD16
Jul 12, 2007 11:08 PM
drewcandraw
Jun 4, 2005 04:03 PM
NaVamous
Oct 22, 2002 09:01 AM
