d16z vtec in crx wiring help
Old Mar 31, 2007 | 07:50 PM
hksdrager's Avatar
Default d16z vtec in crx wiring help
hey im putting this d16 motor from a 93 ex civic in my crx. I have a pw0 ecu i want to use. what rewiring i need to do to use this ecu or should i get jumper and use p28. thank
Old Apr 1, 2007 | 04:53 AM
BlueCrxNC's Avatar
What CRX do you have? (DX/HF/Si) If you have a DX you've got a little more work ahead of you: MPFI Conversion.
If you plan to do any proper tuning then you should go ahead and convert to OBD1 and use a P28 or similar ECU.
Old Apr 1, 2007 | 06:38 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: (BlueCrxNC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueCrxNC &raquo;</TD></TR><TR><TD CLASS="quote">What CRX do you have? (DX/HF/Si) If you have a DX you've got a little more work ahead of you: MPFI Conversion.
If you plan to do any proper tuning then you should go ahead and convert to OBD1 and use a P28 or similar ECU.</TD></TR></TABLE>
yup agreed....
Old Apr 1, 2007 | 10:27 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: (dgonzals)
i second that, just do it right and convert to OBD1. You'll need to either swap the plugs over from your distributor onto the Z6's or use a distributor adaptor. Also get an ECU adaptor for the P28. You'll also need for wiring a subharness to connect the VTEC solenoid and pressure switch and a 4 wire O2 harness. If you have an Si you can reuse your injectors and resistor box or delete the resistor box and use the Z6's injectors but will have to solder on the obd1 injector plugs. The only other thing is you'll have to extend the wires for the fan switch from the back of the block to the thermostat housing on the Z6.
Old Apr 1, 2007 | 04:47 PM
hksdrager's Avatar
im using a hf crx. ok u said i can use the si injectors i got that part. im a little lost on the wire to extend the fan switch to the therostat. so i spilce the fan switch wire and contect it to the thormostat?
Old Apr 1, 2007 | 04:49 PM
hksdrager's Avatar
maybe theres a guide out there i can follow?
Old Apr 1, 2007 | 06:03 PM
Bee17hatch's Avatar
Default Re: (hksdrager)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hksdrager &raquo;</TD></TR><TR><TD CLASS="quote">im using a hf crx. ok u said i can use the si injectors i got that part. im a little lost on the wire to extend the fan switch to the therostat. so i spilce the fan switch wire and contect it to the thormostat?</TD></TR></TABLE>
the cooling fan switch on a crx is mounted on the block next to oil pressure switch
and z6 is mounted on a thermostat housing, you just need to extend the wires.
Old Apr 2, 2007 | 09:08 PM
hksdrager's Avatar
ok i understand that now
Old Apr 3, 2007 | 08:58 PM
hksdrager's Avatar
im still having problems hookin up the fan switch i dont konw what colors they are. thanks
Old Apr 4, 2007 | 05:30 AM
hksdrager's Avatar
bump
Old Apr 4, 2007 | 05:33 AM
ludesrv's Avatar
After all that ecu talk I'll let you in on a secret.
Send your ECU to CRX Toad and have him chip your OBD0 ecu to a P28 spec (best thing to do in your situation). His signature has a link to his site with prices and what he can and can't do. Tell him I sent you.
Old Apr 4, 2007 | 05:43 AM
hksdrager's Avatar
what color are the wires on the for the fan switch on the crx?and were on the d15 do i plug into? the brown sensor? ty
Old Apr 4, 2007 | 07:28 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hksdrager &raquo;</TD></TR><TR><TD CLASS="quote">what color are the wires on the for the fan switch on the crx?and were on the d15 do i plug into? the brown sensor? ty</TD></TR></TABLE>
The sensor will look like that. Notice you have 2 prongs, you will have 2 female recepticals with a grommet over it.
Honestly, plug everything else and look at whats left over and do the math...
Old Apr 4, 2007 | 05:45 PM
hksdrager's Avatar
ok ty for help but i kind of new that part i need to know the color of the wires that pluged into that. for 89 hf
Old Apr 5, 2007 | 04:39 AM
ludesrv's Avatar
I don't know why you want to know the color, they are all plug and play. You litterally can't mess it up unless you have something wrong with your wiring, or your engine.
Old Apr 5, 2007 | 09:00 AM
nickeynick's Avatar
Default Re: d16z vtec in crx wiring help (hksdrager)
i did this swap it was easy. good luck!
http://www.angelfire.com/d20/h....html
CRseXy
11
Dec 30, 2004 11:29 AM
robichaux
Apr 7, 2004 11:25 PM
ID_ten_T
Feb 5, 2004 06:52 PM
jrd16crx
Mar 12, 2003 08:15 AM
