electrical problem, need help please! (searched)
Old Mar 31, 2007 | 07:27 PM
ITLNstallion818's Avatar
Default electrical problem, need help please! (searched)
ok, so this is for a 97 civic ...
ok so i get in my car today... and my left HID is arcing... like sorta flickering... and then it comes back to normal... so im thinking its a grounding issue for that... secondly, my speeometer is all messed up... it will just bounce around everywhere (and might sometimes start acting normal)... and thirdly, i noticed that just at idle... ALL of my lights (exterior an interior) are flickering (kinda "pulsating")... what do you guys think this could be? i think all of these problems are related, because they all seemed to occur today
Old Mar 31, 2007 | 07:37 PM
jdmracer12's Avatar
Default Re: electrical problem, need help please! (ITLNstallion818)
sounds like either your alternator is starting to go or you have one heck of draw somewhere
Old Mar 31, 2007 | 08:01 PM
hall97civic's Avatar
Default Re: electrical problem, need help please! (jdmracer12)
either, bad alternator, bad battery, bad battery cables (most likely ground) or one serious short in the wiring. Oh, and jdmracer12, can I have the girl that's in your avatar?
later,
robert
Old Mar 31, 2007 | 10:54 PM
jdmracer12's Avatar
Default Re: electrical problem, need help please! (hall97civic)
shes all mine
Old Apr 1, 2007 | 02:57 AM
10secwantabe's Avatar
Make sure your chassis grounds are cleaned and greased.
Old Apr 1, 2007 | 08:03 AM
spoon_ek9's Avatar
any check engine light?
Old Apr 1, 2007 | 11:15 AM
Default Re: electrical problem, need help please! (spoon_ek9)
no CEL... i had the alternator tested, and it was at like 67 amps... which he said wasn't too bad... the weird thing about my gauge cluster is, it'll be all weird bouncing around and then after awhile, it will like come back to normal until i turn my car off and drive it later...
now what could cause the gauge cluster to act all weird and then come back to normal??
Old Apr 7, 2007 | 05:03 PM
ok, alternator is fine... i just bought a new battery (mine was considered "bad" cuz it tested 10.6)...
i had a lot of spliced wires for my sidemarkers, city lights, etc., so i re did all of those connections, soldering, etc., cleaned all of the grounds from the valve cover, tranny, battery (anywhere else?), and then cleaned up the two grounds right behind the headlights...
-my speedometer is still bouncing around everywhere while im driving, if not just sitting at 0
-my idle still sits at like 1500rpm even after fully warmed up
-my lights "pulsate" as im driving (bright/dim).. but they do it sorta rapidly... not slow and looping that might be characteristic of a bad alternator...
what else should i check?
jkalex05
Aug 24, 2009 12:43 PM
bengay
Aug 1, 2009 08:45 AM
accrdwgnguy
17
Jan 6, 2009 03:24 PM
SupraRXZ
Mar 20, 2007 07:52 AM
JCritt
Jun 24, 2004 07:28 PM
