Need help from Toda B w/ Power FC users
could anyone who had experiences or who is currently using toda B cams and Power FC provide me a base map (or the settings), so i could work on it from there.
Thx in advance
Here are there info of my car:
USDM B18C5 Stock compression
Mugen Intake
Toda Header
Apexi N1 exhaust w/ test pipe
Toda Spec B cams and Valve Train
290CC Prelude injectors
Apexi power FC
Walbro 255LPH Fuel Pump
Fuel Pressure Regulator
68 mm bored Throttle body
Ignition Timing @ distributor is 18 degrees
94 Octane gas from local gas stations
Modified by Mugen_DC2R at 4:13 AM 4/7/2007
Thx in advance
Mugen Intake
Toda Header
Apexi power FC
Take your car to an Apexi PowerExcel dealer and have them tune the car. PowerFC is as simple as setting it to "autotune" and letting the ECU do its job. Autotune gets you a better basemap than anyone here can provide.
