Am I flooding my motor? <Walbro 255>
i just de-turboed my b18b1 but i was wondering if the walbro fuel pump i have in there would make my car run like garbage? i have an aftermarket pressure regulator and stock injectors, cold air intake, header, exhaust, high flow cat
as long as your feul pressure can handle the flow there is no reason why the car will ever even notice the larger pump.
BUT, if the regulator can not keep up your idle will be messed up.
a fuel pressure gauge will tell you if you're fine or not.
the car will run poorly if you had the car tuned with bigger injectors and the turbo, then if you only took out the turbo and left the injectors in without getting a tune.
centraldriver29
Jun 5, 2014 04:55 AM
Djbower1
Dec 27, 2005 02:56 AM
