whats better 4 a all motor
i wanna keep the stock gsr block n build off that n i heard the b16 trannys are weaker the itr's as far as the head i want something that i can rev the **** out of n i dont think a gsr head is good 4 that
first of all any stock head, or any head for that matter, wouldn't last long if you wanna rev the **** out of it, whether if its a gsr, b16, or type r. USDM type r tranny is basically a b16 tranny with lsd as cooper stated, but a JDM type r tranny is different. Do some research about engine building, know what kind of racing your going to be doing, set a price range, set an acheivable power with that price range, and then start your build.
Modified by blu3g at 11:28 AM 4/2/2007
the b16 tranny has a 4.40 final drive which the usdm and 96-97 JDM ITR trannys have, the 98+ spec itr tranny has a 4.70 final drive
as for the head, if you plan to keep it stock bottom end then get a gsr head and upgrade the valvetrain. If you use a b16/itr head you will get slightly better flow but lose compression due to the larger combustion chamber volume.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mohr610 »</TD></TR><TR><TD CLASS="quote">i wanna keep the stock gsr block n build off that n i heard the b16 trannys are weaker the itr's as far as the head i want something that i can rev the **** out of n i dont think a gsr head is good 4 that</TD></TR></TABLE>
and what good would revving the **** out of it be?
you have lots to learns. start here: https://honda-tech.com/zerosearch
Zero4488
Jun 22, 2005 04:17 PM
NSTY Z33
Jul 28, 2004 01:19 PM
