Suspension & Brakes Theory, alignment, spring rates....
swaping suspension
Old Mar 31, 2007 | 07:38 AM
superg6819's Avatar
Default swaping suspension
Will the stock suspension on my 95 civic ex fit on my 00 civic si? Then i want to take the suspension on my si (skunk2 coils and kyb shocks) and put it on my ex, will this all work?
Old Mar 31, 2007 | 08:02 AM
PIC Performance's Avatar
Default Re: swaping suspension (superg6819)
The rear shocks of your EX will not fit the Si rears perfectly. You'll need to add 5mm of washers on each side of the bushing on the SI's rear lower control arm, because the EX's rear shock fork is wider than the Si's.
Likewise, the bushing on the EX's rear lower control arm is wider than the Si's, so the shocks from the Si will not fit over the EX's rear lower control arm without modification to the bushing.
Old Mar 31, 2007 | 08:27 AM
superg6819's Avatar
Default Re: swaping suspension (PIC Performance)
modifying the bushings meaning cutting them smaller to fit?
Old Mar 31, 2007 | 08:58 AM
Yeah I think you'd have to. Unless your current shocks were originally designed to fit the EX, and were modified from the manufacturer with washers or what not to make it fit the Si. I'd check that before shaving the bushing down on your EX.
aquito
Oct 22, 2010 11:29 AM
Skatin2477
Suspension & Brakes
Mar 30, 2010 03:41 PM
marssrocket
Feb 24, 2010 02:29 PM
ED9man
Jul 30, 2005 03:09 PM
WS6Dreams
Dec 24, 2004 01:23 AM
