AEM Big Brake Kit for Integra Civic Del Sol
Old Mar 31, 2007 | 07:20 AM
boosted_sohc's Avatar
Default AEM Big Brake Kit for Integra Civic Del Sol
hey you guys...i juz have a question about this bbk that i saw on craigslist.. here is the add: http://sfbay.craigslist.org/eby/pts/299506973.html i wanted to know if 16's will fit in these things... i have the fno1r-c 5zigens...lemme know. any info would be appreciated. thanks alot.
Old Mar 31, 2007 | 08:45 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: AEM Big Brake Kit for Integra Civic Del Sol (boosted_sohc)
I'm positive you'll have to run at least a 16" wheel with no higher than a 40mm offset.
Old Mar 31, 2007 | 11:05 AM
Default Re: AEM Big Brake Kit for Integra Civic Del Sol (ek forever guy)
thanks adam..i appreciate the info..i was thinkin at least 16's juz like the wilwood kit. i have 16's right now so i shouldnt see any problem....but u think aem is good wit brakes or should i juz stick wit powerslot or better yet the wilwood kits.??
Old Mar 31, 2007 | 12:09 PM
CivicSpoon's Avatar
I'd personally never buy AEM big brakes. The pads sit too far away from the center of the rotor. So eventually when the rotor gets worn down, there will be a lip in the meat of the rotor that will rub on the edge of the pads. My friend called AEM about this issue when he installed them, and they said that there's nothing they can do because that's just the way they are. I've only seen these on 2 different cars, so maybe others haven't had this problem.
Old Mar 31, 2007 | 12:11 PM
doood's Avatar
been there done that
Default Re: (CivicSpoon)
do you want a bbk for bling or actual track time?
Old Mar 31, 2007 | 12:14 PM
Ek Forever y0!
I think the AEM is a good kit. Do a search on it here see what people think.
Wilwood is a proven kit too, if you can find them reasonably priced.
Old Mar 31, 2007 | 12:34 PM
Ek Forever y0!
edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Guaranteed that 99% of this forum will be fine with some GSR brakes and good pads and fluid. Our cars are more limited by contact patch than braking power. Your tires are going to slide before you can lock up your brakes. </TD></TR></TABLE>
I was doing some seaching and I agree with a lot of what was said in this thread.
A GSR caliper on good rotors with good fluid will easliy lock up a civic's narrow tires. Bigger brake kits are more for bling and road racing than anything else. Another important note is for you to swap to rear discs if you don't have them and get rid of the consistent brake fade that follows drums.
I now vote for GSR w/ good rotors and fluids.
^^^ I posted that from another thread, i now have two big brake threads I'm in.
Old Mar 31, 2007 | 12:47 PM
soisauce's Avatar
I looked for information on the aem brake kit but couldn't find any.AEM doesnt produce them anymore but, most of the other big brake kits require 17" wheels for clearance. So if you go look at them, measure it first. If it is 330mm or larger you will need +17" wheels.
Old Apr 1, 2007 | 04:41 AM
Default Re: AEM Big Brake Kit for Integra Civic Del Sol (MeSoHorny)
thansk for that info...i must've overlooked that info coz i swear i went to the aem website 3x but all i ever saw was the info on aem brake pads but thanks dude!!!
Old Apr 1, 2007 | 05:37 AM
Default Re: (doood)
actuall for both..especially im goin to the track next saturday!! thanks for that input mang!!!
Old Apr 1, 2007 | 05:38 AM
i might juz take your word for it...since im not really a serious track guy. the trip to the track next saturday is only my 2nd for this year!!! i prolly juz convert my rear drums to discs instead...thanks adam1
Old Apr 1, 2007 | 05:39 AM
thats why i was kinda apprehensive of buying it since theres not much of a review on aem brakes..thanks alot brah!!
Old Apr 1, 2007 | 06:06 AM
blackdelslo's Avatar
Default Re: (boosted_sohc)
If there going for a good deal theres nothing wrong with that. The aem kit is good but obviously there are better things out there. Like spoon, yum.
Old Apr 1, 2007 | 07:23 AM
Ek Forever y0!
Default Re: (blackdelslo)
Well, spoon is ridiculous as far as price is concerned.
Integra brakes with good fluid/rotors/pads will be plenty to stop the narrow tires of a civic.
Also a lot of Honda brake fade can be eliminated from the rear disc conversion. Big brake setups for hondas are IMO for track guys and hardparkers.
Old Apr 1, 2007 | 10:58 AM
doood's Avatar
and by track, i mean an actual road course not drag racing.
Old Apr 1, 2007 | 06:22 PM
Default Re: (doood)
yep...autocross
Old Apr 2, 2007 | 10:38 AM
doood's Avatar
well not even for autocross as you're typically just driving around cones in a parking lot.
on a road course where you hit high speeds and need to slow down quickly without worrying about brake fade.
jdmboyef9
Suspension & Brakes
Nov 2, 2006 03:41 AM
EggRolla
10
May 11, 2004 05:07 PM
Powered by Honda
Dec 2, 2003 03:09 PM
ILOVEGIRLS
Mar 23, 2002 06:37 AM
2K_TEG
Oct 2, 2001 06:42 AM
