Swapping Odometer?
Old May 25, 2002 | 05:44 PM
93SSPHatch's Avatar
Default Swapping Odometer?
I'm putting a 95SI cluster into my 93CX and I was wondering how I can swap the odometers? Can someone please post a detailed explaination as to how I can do this? I DON"T WANT TO ROLL THE ODOMETER BACK!
Pictures would also be greatly appreciated. . .Thanks.
Old May 25, 2002 | 06:17 PM
93SSPHatch's Avatar
Default Re: Swapping Odometer? (93SSPHatch)
Anyone. . .any advice is more then welcome!
Old May 25, 2002 | 06:49 PM
mattL's Avatar
just keep the whole speedometer since theyre identical, pull the whole cluster take off the plastic cover on the front undo the 4 bolts that are direcly behing the speedo and it'll come right out and then drop in your CX one
Old May 25, 2002 | 11:28 PM
93SSPHatch's Avatar
Default Re: Swapping Odometer? (mattL)
What about all the green plastic with electrical wire running through it. . .I have no problem unsrewing the screws. . .but to pull off the speedo, I need to remove the green plastic stuff. Is there an easy way to do this. . .and are there any precautions I should take before I remove this plastic stuff. I found this picture. . so that you know what I am talking about when I say "green plastic stuff"
[Modified by 93SSPHatch, 12:34 AM 5/26/2002]
Old May 25, 2002 | 11:45 PM
93SSPHatch's Avatar
Nevermind. . .I was able to get it all figured out. . .thanks for the help
awdgsx96
Apr 28, 2012 06:22 AM
udechukwu
May 8, 2009 12:55 PM
maddcrx
Honda S2000
May 7, 2008 05:09 AM
Bangers
Aug 30, 2006 12:15 AM
BigChris
Mar 18, 2003 10:45 PM
