Cooling fan help.
Old Mar 31, 2007 | 05:41 AM
Nickg116's Avatar
Default Cooling fan help.
My car has been leaking antifreeze aound the radiator and it cracked. I got a new radiator and then notice my cooling fan wasnt on. I asume thats why my first radiator cracked. I made a jumper on the coolant temp switch plug and my fan came right on. So i thought it was just the switch. So i got a new coolant temp switch and it still doesnt come on. Checked all the fuse's and relay's. Car never read hot. Going to replace the thermostat tomorrow. Ive seached and check everything the post said. i would just keep the jumper in but it cuts off with the key not the turbo timer. Its a boosted 97 ex. I need it fix not rig. thanks alot guys!!
Old Mar 31, 2007 | 05:47 AM
Syndacate's Avatar
Default Re: Cooling fan help. (Nickg116)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nickg116 &raquo;</TD></TR><TR><TD CLASS="quote">oing to replace the thermostat tomorrow.</TD></TR></TABLE>
When you got rad problems that lead to overheating problems, you usually g2 change the thermostat too. Too much debris is floating around (at least on old ones).
The thermostat's 12 bucks, change that. That should be the first thing you change after you change a radiator - always. Always, always.
I've never seen anybody get away with a car that's 7+ years old swapping radiators and NOT having the thermostat take a ****. It gets jammed up from 7 years of debris flowing through it.
Go change it, the problem will clear up .
Old Mar 31, 2007 | 06:20 AM
Nickg116's Avatar
Default Re: Cooling fan help. (Syndacate)
thanks. What one should i use. I hear some boosted car run 160 temp thermo's or should i run the stock 180?
redbull99
Aug 27, 2015 10:19 AM
Nerdskateful
Jun 3, 2014 03:21 PM
MyRed98Civ
Jan 11, 2014 06:51 PM
hotcivicsi
19
May 15, 2009 01:54 PM
