tach won't go past 6500 rpm???!!!!!
Old May 25, 2002 | 05:40 PM
GSR44's Avatar
Default tach won't go past 6500 rpm???!!!!!
i have a 98 gsr, and when i try to take it up to redline, the tach doesnt go past 6500 rpm. the speedometer keeps going, and the engine seems like it goes past 6500 because when i do it in first, the speedometer goes up to about 40 mph and then i hit the rev limiter which is about where its supposed to be at 8200 rpm. anyone have an idea of what the problem could be? i just had a valve adjustment done, and ever since then, its been doing this. could a fouled up valve adjustment be the cause for this? any and all help is appreciated. TIA.
Old May 25, 2002 | 06:00 PM
mattL's Avatar
Default Re: tach won't go past 6500 rpm???!!!!! (GSR44)
well if the engine keeps on reving and the speedo says youre accelerating, then the tach is broke
Old May 25, 2002 | 06:16 PM
GSR44's Avatar
Default Re: tach won't go past 6500 rpm???!!!!! (mattL)
for the most part, the tach works like its supposed to through out all rpms until it hits 6500, then it stops going.
Old May 25, 2002 | 06:33 PM
mattL's Avatar
yeah sound like its broken, check if the needle gets stuck on something. if you cant fix it you can go two ways. you can spend 100 and buy another gauge cluster or just find an LS cluster which you should be able to buy for real chep and just pull the tach out and and use the gauge face off your gsr so the redline is still at 8k.
Old May 25, 2002 | 06:49 PM
GSRrR's Avatar
do you have indiglo gauges?
Old May 25, 2002 | 06:52 PM
b18bvudoo's Avatar
New User
i have a similar problem; havent gotten around to try fixing it, but some people tell me it might be my distributor rotor.
Old May 25, 2002 | 07:24 PM
GSR44's Avatar
Default Re: tach won't go past 6500 rpm???!!!!! (vudoo666)
nope...stock gauges. i've never messed with them at all. i've had the car for about 20K miles, and it just started happening.
vudoo: hopefully the people who tell you its the distributor are correct cuz i would rather change the cap and rotor than mess w/ all the electronic stuff in changing the gauges.
[Modified by GSR44, 8:26 PM 5/25/2002]
TcUiRvBiOc
Sep 10, 2009 02:59 PM
Dr_drache
Aug 12, 2007 05:40 PM
sohctodohc
12
Oct 10, 2005 11:44 PM
GSR44
May 25, 2002 08:26 PM
