FS: Pioneer GM-5100T amp CHEAP
This amp is like new and was used very little. I upgraded my system therefore not needing it anymore. Here are the specs
Product Description:
2-Channel Bridgeable Power Amplifier
RMS Power Rating:
4 ohms: 125 watts x 2 chan.
2 ohms: 190 watts x 2 chan.
4 ohms bridged: 380 watts x 1 chan.
Variable Bass Boost: 0 - 12dB @ 50 Hz
Speaker level inputs
Oversized power terminals
LPF Crossover(80 Hz, -12dB/oct)
CEA-2006 Compliant
PWM regulated MOSFET power supply
S/N Ratio: 75dB
Frequency Response: 10 Hz - 50 kHz
Balanced isolator input circuit
Dimensions: 13"L x 12"W x 2-3/8"H
Amplifier Specifications:
Number of Channels 2
RMS Power (4 ohms) 125 watts x 2 chan.
RMS Power (2 ohms) 190 watts x 2 chan.
Bridged RMS Power 380 watts x 1 chan.
Peak Power Output 760 watts
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power <1.0%
Speaker Level Inputs Yes
Built-in Crossover Yes - LP
Low-Pass Crossover 80 Hz
Signal-to-Noise Ratio 75 dB
Bass Boost 0 - 12 dB @ 50 Hz
Fuse Rating 30A x 2
I am asking $65 shipped for this amp. PM me if you eould like pictures.
Chris
RMS Power Rating:
CEA-2006 Compliant
S/N Ratio: 75dB
Fuse Rating 30A x 2
Chris
Aloha04MSM
Mar 22, 2006 07:46 PM
