need help asap!!! thanks
Old Mar 30, 2007 | 11:02 PM
freddysEF's Avatar
Default need help asap!!! thanks
I change my wiring harness from the motor to the dash in my 90 civic hatchback. What i did, i disconnected all the wires/pins from a plug that connects to the injectors, kock, ect. but i notice that their are two sets of wires that are the same. two yellow, yellow with a black strip. Im not sure which one goes first in the connector, it the two row, from the top which the clip is on.
The second is i cut the whole front left lights but the same problem, there are two black with red spots, and three black with silver spots. Im not sure if i connected them right,
i connect everything, and when i went to try to start the car, nothing will happen, but when i use jumper cables and jumped the starter with the battery the car will turn over but wouldn't stay on. It will just keep turning.
But then i disconnected one of the fuel lines and i turn the key, no fuel will come out and the fuel bump wouldnt turn on.
Can someone tell me why arent i getting no fuel?? I got two things in mine i wired one of the wires wrong but i cant tell if i did because there are the same color and i try to switch them but nothing, second fuel bump is bad which i will test tomorrow.
So if anyone can give me Ideas that will be great
thanks
freddy
LowAcura
Dec 24, 2007 12:00 AM
Jhonny Ricer
Aug 1, 2007 09:10 AM
Immanuel
Jul 8, 2005 08:42 AM
lococoin
Feb 4, 2005 01:59 PM
WickedWerx
Oct 23, 2004 02:32 PM
