spindle swap.
Old Mar 30, 2007 | 09:01 PM
nihad's Avatar
Default spindle swap.
I have a 91 crx si full brake swap on my 89 si civic. I was woundering if i buy the 94 si and ex brembo full rotor kit for like 160$ WOuld it fit my front spindle. If not whats the diffrence and how to fix it. Are the spindles the same or could i just switch to 94 ex breake calipers. Has any one done this. I think the newer disks are like 10in and mine are like 9.5.
Old Mar 30, 2007 | 09:30 PM
ALLMOTORCRX20's Avatar
Default Re: spindle swap. (nihad)
Just buy the front knuckles from the 94 SI or EX with everything and put it on your car. It will bolt right on.
Old Mar 31, 2007 | 08:45 AM
nihad's Avatar
Default Re: spindle swap. (ALLMOTORCRX20)
i dont think the sway bar will work on it my old one.
Is there a way i could use the old spindles and modify some thing else.
Old Mar 31, 2007 | 09:13 AM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTORCRX20 &raquo;</TD></TR><TR><TD CLASS="quote">Just buy the front knuckles from the 94 SI or EX with everything and put it on your car. It will bolt right on.</TD></TR></TABLE>No it won't work at all.
Old Apr 1, 2007 | 09:18 PM
nihad's Avatar
Default Re: spindle swap. (dr_latino999)
The only thing is that the 95 ex abs rotors are like 10 in or little bigger and my stock one are like 9 or 9.5 would the 95 abs rotor fit my 91 si spindles. Or i would have to buy the 95 one. to make it work.
whitelightning
Feb 21, 2006 11:15 AM
xisda1
Jan 27, 2006 07:53 PM
Blindstuff
15
Mar 30, 2005 12:39 PM
94siturbo
Feb 20, 2004 03:47 PM
six.lug.steph
10
Jun 25, 2002 06:48 PM
