Suspension & Brakes Theory, alignment, spring rates....
race suspension ?
Old Mar 30, 2007 | 05:21 PM
neophyte210's Avatar
Default race suspension ?
i have a eg hatch currently turbo but i am currently building a fully built NA motor .. the car has gsr brakes all the way around and stainless braided lines ... what im curious about is will integra front lca's fit on my car? i was planning on 24mm front and 22mm rear i have strut bars and d2 coilovers currently ... and the other thing is im thinking about goin past azenis rt-615 and goin straight to a race tire like avon
help is appreciated
Old Mar 30, 2007 | 06:50 PM
MyEG6's Avatar
Default Re: race suspension ? (neophyte210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neophyte210 &raquo;</TD></TR><TR><TD CLASS="quote">i have a eg hatch currently turbo but i am currently building a fully built NA motor .. the car has gsr brakes all the way around and stainless braided lines ... what im curious about is will integra front lca's fit on my car? i was planning on 24mm front and 22mm rear i have strut bars and d2 coilovers currently ... and the other thing is im thinking about goin past azenis rt-615 and goin straight to a race tire like avon
help is appreciated</TD></TR></TABLE>
Integra front lower LCAs will fit. Race tires will make a world of a difference. Good luck on your build!
BTW: I have a pair of integra front lower lcas if you need some. And a 24mm front sway with bushing/brackets/endlinks.
Modified by MyEG6 at 8:04 PM 3/30/2007
Old Mar 30, 2007 | 10:18 PM
Default Re: race suspension ? (MyEG6)
awesome
Old Mar 31, 2007 | 01:59 AM
GarageAlchemist
Guest
Posts: n/a
the d2's are a bit of a waste, nothing more than bulk product/non performance item, cheaply made, etc.. koni/gc, so you can tune your setup if your "race" geared
might wanna ditch the front, and just get some track time. What are you going to be racing.. or do you just want a race quality setup for the street..
Old Mar 31, 2007 | 07:44 AM
Default Re: race suspension ? (GarageAlchemist)
would it be worth gettin rid of my d2's for something like koni/gc ... ive heard there an awesome setup
Old Mar 31, 2007 | 09:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">might wanna ditch the front, and just get some track time. What are you going to be racing.. or do you just want a race quality setup for the street..</TD></TR></TABLE>
whats wrong with front sway??? i plan on racing but until i get everything setup its gonna be street ... but mostly race considering i have a 4.9final in a jdm itr tranny
Old Mar 31, 2007 | 11:04 AM
GarageAlchemist
Guest
Posts: n/a
most people don't run a front sway, depends on what you like on the track thow, every setup is diffrent, as far as d2.. i wouldn't trust much track time with them. d2 isn't an actual tunner company, there shocks are just bulk made .tw crap. I would stick with something you can tune, and trust such as koni/gc
Old Mar 31, 2007 | 02:57 PM
PIC Performance's Avatar
There is nothing wrong with running a front swaybar; I've seen just as many racecars with the front sway than without, and there can be arguments made for both. Race with and without it, and see which you prefer, because in the end the setup should suit the driver, not the driver suiting the setup.
Old Mar 31, 2007 | 03:16 PM
Default Re: race suspension ? (PIC Performance)
pic what do you think about d2's ... ive been looking around and they are pretty expensive ... i got them off a friend should they do pretty good or should i consider converting to koni/gc
Old Mar 31, 2007 | 03:17 PM
You're asking the wrong guy, sorry.
Old Mar 31, 2007 | 03:20 PM
no problem man ..
tronic
26
Apr 19, 2007 02:07 PM
Un0Turb0-WP
Suspension & Brakes
Jan 26, 2005 10:25 PM
Jared
Sep 2, 2004 11:21 PM
gillyfesh
Mar 27, 2004 08:00 PM
LudeToAHatch
Jun 27, 2003 07:21 AM
