Car Overheated!!!!!b20 vtec Need HElP!!!
Aite so i was driving home today and all of a sudden i start to hear some noise coming from timing belt area and thought it was my water pump. After the noise car jerks and shot up to 3/4 on temp gauge i quickly pull over. Sat for almost an hour on side of freeway to let motor cool all the way down. Drove another 10 miles to get a little closer home so i wouldnt get raped for tow. Drove ok then after 10 mins started up again and i pulled off as it went to 3/4's again i put it in neutral before shutting it down and it seemed that my car turned of before i got a chance. Got it Towed drove it in my garage from driveway and heard shaky terrible noise. Parked drained oil and i have slight coolant in oil so i know i popped a gasket but wtf was the shaky noise. Thought for sure it was water pump but now i cant tell where its coming from. Def not timing belt area. Any ideas? DO NOT WANNA rebuild. Hope its nothing or the eggs gonna be sitting...
From: chillin in that city called queen creek, but homes the atl
i would say pull your plugs and see if theres coolant or oil on them that would explain your shaking. but your problem is blown head gasket or cracked sleeve
pulled the plugs and they look fine. When i drained my oil there was only a slight milky look too it. I hardly lost any coolant. Heads coming off tomorrow so well see how it looks. Also did compression test and all but one where at about 180. One cylinder read about 145. I was thinking thats gotta be where the gaskets blown? If i had cracked a sleeve or rings were gone wouldnt it read alot less?
any ideas on what caused the overheating? Radiator fan stays on at all times. Thinking thermostat? Because all of a sudden my radiator fan stopped working. even after changing the switch it doesnt work. But as soon as i put direct power to it it works fine.Fan stop working about a week ago and ive had it direct to power since. Is thermostat sticking and how to tell? so coolant in oil causes shaking sound? After second overheat coolant filled up in reservoir and was bubbling up. only felt shaking after getting it home i pulled it into the garage.
HondaFanatic708
Mar 31, 2005 06:08 PM
riceburners1
13
Jun 2, 2004 10:57 AM
