crx dont start
Old Mar 30, 2007 | 04:08 PM
joecrx's Avatar
Default crx dont start
hi can eny 1 help me with this problem
i have honda civic crx 92 D16A9 some time dont want to start wen it dont want to start i dont hear the fuel pump dont matter if its cold or hot.i leave it some time it works
Main Relay 100% ok i testd it.ignition switch is new.
Old Mar 30, 2007 | 05:22 PM
turbo1rx's Avatar
Default Re: crx dont start (joecrx)
when I dont hear my fuel pump go on its cause of the main relay but when i took off the black cover and squeezed two ends of the relay and turn the key it works I know a guy who has a rubberband to hold it tightly LOL but yeah make sure it doesnt work when you try what I just mentioned if it doesnt then look here
https://honda-tech.com/zero...94739
Old Mar 30, 2007 | 10:05 PM
ALLMOTORCRX20's Avatar
it sounds like its the main relay because that powers up the pump
unless you have a open circuit to the relay
it could also be that your fuel pump is messed up, but if this was the case
then it would never start
try a main relay that you know for sure its in good working condition
Old Mar 31, 2007 | 02:41 AM
joecrx's Avatar
Default Re: crx dont start (ALLMOTORCRX20)
i did the k-test im reading 4.9volts. i think i have to chang ECM
Old Apr 3, 2007 | 11:23 PM
how did you test the main relay??
bigjefft
Apr 22, 2012 12:24 AM
grkblood13
Aug 28, 2008 04:22 PM
uszcrx
24
Sep 9, 2006 01:05 PM
Hugsnkisses01369
Aug 18, 2006 02:46 PM
MooreBoost
10
Sep 8, 2004 07:43 PM
