Main Relay Location
Old Mar 30, 2007 | 03:05 PM
lledcomp's Avatar
Default Main Relay Location
I have a 99 honda civic that i'm sure the main relay has went out on. Problem is that I can't find the relay. Where is it at? Detailed instructions because they all look alike and I hate electrical.
Old Apr 1, 2007 | 02:34 AM
rickypwp1985's Avatar
Default Re: Main Relay Location (lledcomp)
behind the glove box towards the right i think well i have a 97 civic and thats where its at.open the glove box and look tru the space on the right side
Old Apr 1, 2007 | 03:07 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Main Relay Location (rickypwp1985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rickypwp1985 &raquo;</TD></TR><TR><TD CLASS="quote">behind the glove box towards the right i think well i have a 97 civic and thats where its at.open the glove box and look tru the space on the right side</TD></TR></TABLE>
Open the glove box and look to the right. Its attached to the passanger side dash by a 10mm nut.
Old Apr 1, 2007 | 04:28 AM
R-81DC2's Avatar
Default Re: Main Relay Location (wrx-killer-Sti eater)
take it out where ever u go
Old Apr 1, 2007 | 11:55 AM
BlueIntegraBoy's Avatar
Default Re: Main Relay Location (R-81DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatGuy4life &raquo;</TD></TR><TR><TD CLASS="quote">For future references:
To get to main relay on 2000 civic si, you need to reomve the panel on the far right side of the dash
then drop you glove box look inside where the glove box was to the right and you will see the main relay (don't mind all the wires you see in my pics, those are to the relays for my door poppers so yours won't look exactly like mine)
you can also see it from outside
It's being held by a 10mm bolt
remove the bolt remove the relay from the bracket and remove the connector, install in reverse.</TD></TR></TABLE>
Old Apr 20, 2007 | 08:38 PM
the.hamburglar's Avatar
Default Re: Main Relay Location (BlueIntegraBoy)
great info, would this relay be in the same location for a 94 del sol? is there anyway to test it?
hondamonkey
Dec 13, 2005 12:21 PM
FLCivic
Aug 19, 2005 08:46 AM
importimage
May 16, 2005 05:49 PM
JOHN WAYNE
Jul 11, 2002 02:23 PM
