Suspension & Brakes Theory, alignment, spring rates....
Springs in the front way more then rated
Old Mar 30, 2007 | 02:30 PM
GraphiteMW's Avatar
Default Springs in the front way more then rated
I installed H&R race springs the other day and my front end is tucking tires and I am only on stock 15's. Every picture I see with h&r race springs on the prelude it looks nothing like my car.. the front end is extremely low and the back end has a reasonable rated drop.
What could it be? I don't remember seeing bump stops.. could that be the problem?
Old Mar 30, 2007 | 02:49 PM
Tyson's Avatar
Default Re: Springs in the front way more then rated (GraphiteMW)
two obvious suggestions:
you installed it wrong. check and reinstall.
the springs were labelled wrong or you installed them wrong front/back. check and reinstall the other way to be sure.
would have nothing to do with bumpstops. or the age of your shocks.
Old Mar 30, 2007 | 03:06 PM
GraphiteMW's Avatar
Default Re: Springs in the front way more then rated (Tyson)
I installed as labeled.. I put the longer springs in the rear and the shorter ones in the front. I am 100% sure I mounted them correctly because i've done suspension installlations ebfore and NEVER ran into this problem.
It couldn't be that my front shocks are blown?
Old Mar 31, 2007 | 09:04 PM
dfoxengr's Avatar
shocks dont do anything statically normally, so thats not why its lower than youve seen.
Old Apr 1, 2007 | 07:35 AM
seadonkeyraypiss's Avatar
Are you sure you installed them correctly? My front springs are longer than my rear springs to account for the weight of the motor.
///Mathew
11
Sep 18, 2011 04:09 PM
hondabadtoy
Suspension & Brakes
Apr 3, 2008 08:40 PM
BLANCOh22a4
May 31, 2007 06:31 PM
ds2000
Sep 4, 2003 12:30 AM
ngolimit408
Nov 4, 2002 07:31 AM
