gsr/ef clearances
Old May 25, 2002 | 02:20 PM
B pwr's Avatar
Default gsr/ef clearances
ill be putting a gsr b18c into my 90crxsi later on in the year(hasportmounts billet)
1.my car right now is 2.25 all the way around, is that to low for this motor?
i hear 1.8 hang a little low or can afford to go slighlty lower if i wanted to?
2. crossmembers need to be modified for any type header?
3. i believe the webbing in the hood , needs to be modified correct ?
4. i want to use a type r or si,gsr trannys(hasporthydro kit) , phsically will they fit?or will it be a real hassle?
5. anything else i should look for?
thanx
[Modified by crxpwr, 11:21 PM 5/25/2002]
Old May 25, 2002 | 05:36 PM
Jonathan_ED3's Avatar
Default Re: gsr/ef clearances (crxpwr)
thanx
you might want to get a less aggressive drop. 2.25" might be pushin it and you might have to worry about bustin your pan.
crossmember needs to be modified in the same way as it does for the b16 swap..which isn't very much at all.
the webbing in the hood MIGHT need to be cut out. not positive though. the clearance isn't really THAT much worse than a b16 swap. whatever you do, don't sacrifice engine height to clear your hood...i.e. shimming the engine down. if you need more clearance, get an SiR style hood for your USDM front, or a complete SiR front end conversion.
yeah the transmissions will fit. people say there's not enough room, but there's bee a couple guys who have easily gotten the Type R tranny (which is the 'biggest' physically because of the LSD and all) to fit. However, they were using the HCP kit from what I understand.
Email this guy named Jon at NC_Rex@hotmail.com he knows a great deal about the GSR/EF swap. Good luck.
Old May 25, 2002 | 05:53 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
I had about a 2 inch drop. It fitted just fine and no problem with the
radious rods. My friend's (B18C5 CRX) has about 2.5" drop and his is fine as well.
We both have Hasport mounts.
If you use Hasport and DC 4-2-1 header, you will not need to modify the cross member.
If you use a 4-1 header, you will have to modify the cross memeber.
Yes, but only directly above the valve cover
It fits just fine. We went the hard way and converted the CRX to Hydro clutch
but if you get the Hasport kit it should be no problem.
thanx
cvrtsniper
10
Apr 8, 2009 04:24 AM
skiracer8148
Nov 8, 2005 02:47 PM
DC2 B18C TSL
Nov 25, 2003 11:03 PM
DC2 B18C TSL
Nov 25, 2003 10:47 PM
importfreak02
Dec 26, 2002 05:46 PM
