Upgrading to Vband exhaust housing....
Old Mar 29, 2007 | 07:57 PM
95GSRTT
Guest
Posts: n/a
Default Upgrading to Vband exhaust housing....
How hard it is to get a vband housing for a t3/t4 turbo? Right now I have the Garrett 60 trim .63 A/R 4 bolt exhaust housing and it would make things 1000x easier getting a vband housing.
The only place that I notice might sell it is ATPTURBO and they state its only for when you purchase a turbo from them. I cant use an adapter as its for a AC manifold/downpipe and there isnt enough room for the downpipe to be extended.
Old Mar 30, 2007 | 02:06 AM
blackeg's Avatar
Default Re: Upgrading to Vband exhaust housing.... (LeGeND4LiFe)
you can get the adapter too, which bolts into your turbo housing and the other side is vband for your downpipe. i did this and it made my life 1000x easier. my entire exhaust is now vband cus its easy
Old Mar 30, 2007 | 02:46 AM
Monstah's Avatar
V band does make things alot easier. Easy to make adjustments to your exhaust, easy to take exhaust off, get best angle of your turbo, etc.
Old Mar 30, 2007 | 04:59 AM
tony1's Avatar
Default Re: (Monstah)
That's what i do, just weld the vband flange to the housing.
Old Mar 30, 2007 | 08:44 AM
95GSRTT
Guest
Posts: n/a
Default Re: (tony1)
would a vband flange need to be tig welded on or can you mig weld it on to the housing?
Old Mar 30, 2007 | 09:01 AM
splitime's Avatar
Default Re: (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">would a vband flange need to be tig welded on or can you mig weld it on to the housing?</TD></TR></TABLE>
Mine was migged on and its holding fine for 22k miles and over a year.
Old Mar 30, 2007 | 09:23 AM
blinx9900's Avatar
Default Re: Upgrading to Vband exhaust housing.... (95GSRTT)
i just ordered an adapter for the exact same thing from http://www.kms-fab.com/trans_vband.html the guys are awesome!! there also here on h-tech pm user "kordenbrock motorsports" whats listed on the site is an example im pretty sure they can do it anyway and size you want ie: 5 bolt to vband or 4 bolt to vband 3" 4" what ever they can do it. this was my first time dealing with them and i was really impressed look for a full write up in the future.
Old Mar 30, 2007 | 09:27 AM
tony1's Avatar
Default Re: Upgrading to Vband exhaust housing.... (blinx9900)
You still have to deal with bolts wanting to back out with the adaptors, not to mention they take up a lot of extra space that most don't have to work with.
Old Mar 30, 2007 | 09:52 AM
B18EG6's Avatar
OP-
what kind of manifold is this?
I dont know if you are interested, but I have a .63A/R 5 bolt turbine and a v band kit for it, if it would help you out check the signature
Old Mar 30, 2007 | 10:13 AM
blinx9900's Avatar
Default Re: Upgrading to Vband exhaust housing.... (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">You still have to deal with bolts wanting to back out with the adaptors, not to mention they take up a lot of extra space that most don't have to work with. </TD></TR></TABLE>
you can always convert bolts to studs, and if they want to back out of the adapter then they would want to back out of the dp so you have that problem no matter what. extra space? ehh like 2" but im guess most people in this boat like myself are having custom dp built?
Old Mar 30, 2007 | 10:18 AM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
I had the adapter on my civic and it sux do it right the first time have it welded on the housing you will be happier in the long run Tony did mine and it turned out awesome
Old Mar 30, 2007 | 10:24 AM
blinx9900's Avatar
Default Re: Upgrading to Vband exhaust housing.... (gunslinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunslinger &raquo;</TD></TR><TR><TD CLASS="quote">I had the adapter on my civic and it sux do it right the first time have it welded on the housing you will be happier in the long run Tony did mine and it turned out awesome</TD></TR></TABLE>
pics? why did it suck? please explain.
Old Mar 30, 2007 | 11:52 AM
95GSRTT
Guest
Posts: n/a
Default Re: Upgrading to Vband exhaust housing.... (B18EG6)
Its a ramhorn from AFI. Its a 4 bolt Garrett housing and the DP has already been made to fit this set up. I just thought I try switching housings or maybe weld on a vband on the downpipe and the housing. Sounds like the best way to go. Is it best to have the housing machined down and then weld on the vband? or can you just weld it on like is. I can mig weld it on myself which would probably help with pricing.
And ya the extra 1.5 inches is not really feasible as its for an AC manifold and it would more than likely hit the AC compressor if moved out further if I remember correctly.
Old Mar 30, 2007 | 12:13 PM
thermal's Avatar
I have bought the adapter separately. I got mine from Boostfed....
Old Mar 30, 2007 | 12:37 PM
Dunc's Avatar
BCICAN
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">That's what i do, just weld the vband flange to the housing. </TD></TR></TABLE>
Tony, this is what I was planning to do also....but one thing I was concerned about is all that heat from tig welding it to the exhaust housing on the turbo. Could that build up of heat do anything harm to the turbo? Should I weld it in small patches and allow it to cool in between or just weld and call it a day?
Old Mar 30, 2007 | 12:38 PM
Schister66's Avatar
Man U FTW
just weld it on....the adapters are great, but only if you have the space....personally i would just have it Tig'd on and forget about it...
Old Mar 30, 2007 | 12:43 PM
95GSRTT
Guest
Posts: n/a
Default Re: (Dunc)
why would it do harm to the turbo? You can just take the housing off and weld it on that way and then put it back on.
Old Mar 30, 2007 | 12:49 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">why would it do harm to the turbo? You can just take the housing off and weld it on that way and then put it back on. </TD></TR></TABLE>
If I knew then I wouldn't be asking I won't be taking the exhaust housing off the turbo if and when it's welded on. The turbo will be in one piece...if I took it apart then yea I know it wouldn't harm anything.
Old Mar 30, 2007 | 12:50 PM
95GSRTT
Guest
Posts: n/a
Default Re: (Schister66)
So when you guys get the weld on done? did you machine down the existing 4 or 5 bolt on the housing so that it was alot more flush with it?
Old Mar 30, 2007 | 12:59 PM
tony1's Avatar
Take the housing off the turbo when you weld it, it's simple enough to remove and not worth the risk of the possibility that it will hurt the turbo.
Old Mar 30, 2007 | 01:06 PM
Dunc's Avatar
BCICAN
Default Re: (tony1)
cool beans, thanks for the info.
Old Mar 30, 2007 | 01:48 PM
Monstah's Avatar
Default Re: (Dunc)
absolutely. no need to risk getting any weld splatter/slag on anything.
Although, the TIG doesn't throw much, if any.
Old Mar 31, 2007 | 02:40 PM
gunslinger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
pics? why did it suck? please explain.</TD></TR></TABLE>
because the bolts backed out still ... then i put studs and nuts then tacked welded it. and it broke the welds and the nuts backed off.. After I had the vband welded to the housing I have had zero issues with it.
Old Mar 31, 2007 | 02:41 PM
tony1's Avatar
V Bands are better... just because....
Old Mar 31, 2007 | 02:48 PM
le0ftw's Avatar
KOBE IS GOD
i had my old sc61 like that
