will these 88 BMW rims fir on my 00SiR
Found a good deal on some rims that came off an 88 BMW 325 IS. they are 4 x100, 14x6.5", not sure of the off-set yet . Just wondering if anyone knows if they will work ,or if i'll have cailper, or rubbing issues. Just looking to put them on as a winter set. I'm getting some mixed reply's on another forum.
Modified by Skidkid43 at 2:55 AM 3/30/2007
Sexy wheels. They should fit fine. This guy has those same wheels on his ek hatch. https://honda-tech.com/zerothread?id=1912933
Just double check the offset, older BWMs rims normally stuck out more. Also to note is the bore size is probably 57.1mm where as your honda is 56.1mm, if memory serves me correctly. 1mm shouldn't make much difference though, just something to be aware of.
Cheers.
Cheers.
