Thermal R&D axle back for DC2 (used)
Old Mar 29, 2007 | 06:47 PM
Vitt1's Avatar
Default Thermal R&D axle back for DC2 exhaust (used)
SOLD TO MatrixShark
2.5" piping. Has some very small surface rust spots around some of the welds. (see the pics below about trying to fit with the OEM GSR b-pipe.
Some people have asked me about the fit onto the GSR stock B-pipe. I had this bolted to a custom B-pipe with flat collector flange. Regarding the fit to a GSR stock B-pipe, looks like you may have to do some minor modification and have a 2 bolt collector flange welded at the end of the B-pipe. I had a 94 GSR, so I'm not sure if they changed the design after that.
As you can see, the pipe is extended out past the stock flange, and there is a ring that goes on top of that extension. there is also a sort of covering around the flange that holds a hanger. Looks like the extended pipe is not a good fit inside the 2.5 (I think the GSR is only slightly smaller, and that's the outer diameter of the GSR fitting into the inside of the Thermal pipe. So I suggest you cut that extra piece of pipe and fit the flanges flat against each other, or get a flat flange welded to your existing b-pipe. If you have an aftermarket exhaust with a flat flange you shouldn’t have that problem.
Modified by Vitt1 at 6:38 AM 4/3/2007
Modified by Vitt1 at 8:40 AM 4/3/2007
Modified by Vitt1 at 6:33 AM 4/4/2007
Modified by Vitt1 at 10:43 AM 4/4/2007
Old Mar 29, 2007 | 07:47 PM
IgnitionZ05's Avatar
Default Re: Thermal R&D axle back for DC2 (Vitt1)
will it fit a 01 gsr?
Old Mar 30, 2007 | 06:55 AM
Vitt1's Avatar
Old Mar 30, 2007 | 06:56 AM
Vitt1's Avatar
Default Re: Thermal R&D axle back for DC2 (IgnitionZ05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IgnitionZ05 &raquo;</TD></TR><TR><TD CLASS="quote">will it fit a 01 gsr? </TD></TR></TABLE>
Yes, it will fit a 01 GSR 2 door, not sure about the 4 door.
Old Mar 30, 2007 | 06:59 AM
mike5809's Avatar
got dibs sent pm
Old Mar 31, 2007 | 10:05 AM
Vitt1's Avatar
Default Re: Thermal R&D axle back for DC2 (mike5809)
Up
Old Mar 31, 2007 | 06:04 PM
Vitt1's Avatar
Old Apr 2, 2007 | 05:51 AM
Vitt1's Avatar
still available
Old Apr 2, 2007 | 06:36 AM
Mr.OB*GYN_Rhett's Avatar
crazy cheap price
Old Apr 2, 2007 | 07:24 AM
MatrixShark's Avatar
Default Re: Thermal R&D axle back for DC2 (Mr.OB*GYN_Rhett)
pm sent
Old Apr 2, 2007 | 07:47 AM
Vitt1's Avatar
Default Re: Thermal R&D axle back for DC2 (MatrixShark)
Replied
Old Apr 2, 2007 | 07:16 PM
Vitt1's Avatar
Old Apr 3, 2007 | 05:38 AM
Vitt1's Avatar
All IM's replied.
Old Apr 4, 2007 | 05:33 AM
Vitt1's Avatar
bump
Old Apr 4, 2007 | 06:14 AM
Default Re: Thermal R&D axle back for DC2 exhaust (Vitt1)
Payment sent
disasiandude
Aug 7, 2008 02:52 PM
roninb18
Feb 20, 2003 03:51 PM
ajchen
Oct 4, 2002 09:49 AM
MrSmith
May 15, 2002 02:19 PM
typerlover
Jan 27, 2002 11:25 AM
