Honda Fit Honda Fit (Jazz)
wide rims, low offset?
Old Mar 29, 2007 | 04:43 PM
crxgator's Avatar
Default wide rims, low offset?
i really want to get some work equip 01's...but i was thinking of 15x8 with a 25 offset, i know i would have to roll the fenders, but do you think i would have to cut em and put on flares? should i get a 15x7.5 or 7 and run a spacer instead?
Old Mar 30, 2007 | 07:14 AM
crxgator's Avatar
Default Re: wide rims, low offset? (JJSpecTuning)
so i would probably be best to do a 15 x 7 and add a spacer?
Old Mar 30, 2007 | 09:54 AM
harajuka's Avatar
Default Re: wide rims, low offset? (crxgator)
You can run 15x8 +24 if you wanted to, but the trick is you will have to run streched tires to make it work.
Old Mar 30, 2007 | 11:37 AM
fitfreak3's Avatar
Default Re: wide rims, low offset? (harajuka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harajuka &raquo;</TD></TR><TR><TD CLASS="quote">You can run 15x8 +24 if you wanted to, but the trick is you will have to run streched tires to make it work. </TD></TR></TABLE>
I would like to know if anyone else ran this same setup at that offset, I would really love to do this with mine as well. I currently have 16x7 +35 offset and my fenders are also rolled yet still rubbing a bit on bumps
What kind of stretch are you saying? Maybe 195/50 15's?
Old Mar 31, 2007 | 01:24 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: wide rims, low offset? (fitfreak3)
I'd like to see some pics of an 8" wide wheel on a Fit with a decent offset.
Old Mar 31, 2007 | 01:32 PM
RickyGoshDarn's Avatar
Default Re: wide rims, low offset? (-NA-aLL-thE-wAy-)
The fit is not a ******* drift car.
Old Apr 1, 2007 | 01:04 AM
panayioti-p's Avatar
Default Re: wide rims, low offset? (RickyGD)
Hi mate,
we all know that the fit is not a drift car
its a car that you fix up to drive on the streets
not to go drifting and go to a track!
its an every day car that you can fix up!!!!
and make it look good!!!
Old Apr 1, 2007 | 04:29 AM
Default Re: wide rims, low offset? (panayioti-p)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panayioti-p &raquo;</TD></TR><TR><TD CLASS="quote">Hi mate,
and make it look good!!! </TD></TR></TABLE>
Hahah no ****? Matie
Old Apr 1, 2007 | 06:32 PM
fitfreak3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RickyGD &raquo;</TD></TR><TR><TD CLASS="quote">The fit is not a ******* drift car. </TD></TR></TABLE>
And all this time I thought the Fit was for drifting...
Old Apr 6, 2007 | 05:36 AM
smeister's Avatar
Isnt the Fit RWD??? Seriously though, if they want to put on 15x8 then let them. It is their car. There are worse things they could do to the Fit!
Modified by smeister at 6:56 AM 4/6/2007
Old Apr 6, 2007 | 07:00 AM
crxgator's Avatar
is this from personal experience?
Old Apr 6, 2007 | 02:55 PM
Thirty-Nine's Avatar
Would fender rolling help, too? (I don't know what the fenders are like on the Fits)
Old May 3, 2007 | 03:28 PM
badcf4's Avatar
ok so ive got a honda fit/jazz in my workshop (sorry to drag up an old thread btw) and its running 17x8's @ 35 p and rubs hard.....
going from what ive read here it seems that a 7 @35 will rub also.
anyone able to tell me what will fit without rubbing ???
Old May 4, 2007 | 05:59 AM
WihaSi's Avatar
Default Re: (badcf4)
Shouldn't have a problem with 16x6.5 right? I think that is what the HFP's are. Just curious.
Modified by WihaSi at 11:04 AM 5/4/2007
Old May 4, 2007 | 02:27 PM
jetydosa's Avatar
25 Year Member
What about his post makes you think he is intrested in drifting?
Old May 4, 2007 | 02:48 PM
Milano Sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">so i would probably be best to do a 15 x 7 and add a spacer?</TD></TR></TABLE>
adding a spacer makes the offset even lower! NO you wouldnt add a spacer in this case.
most people run +38 and higher (+40, +42, +45) and have little to no rubbing issues.
anything lower than +38 with a 15x7 or 16x7 or wider rim WILL RUB! there isnt much fender to roll so it doesnt help (i know i had mine rolled and didnt do anything...im running +40 offset...only rubs with 2 adults sitting in the back).
15x8 +40 might work. gotta be careful you dont get too high an offset because you have to worry about the inside rubbing at that point not just the outside.
Old May 17, 2007 | 11:04 PM
n1_egsex's Avatar
* B A N N E D *
Old May 18, 2007 | 06:52 AM
Default Re: wide rims, low offset? (NOT_USDM)
More pics!
Looks like some Schmidt Modernlines ...
Old May 18, 2007 | 07:07 AM
USDMGD3!'s Avatar
Default Re: wide rims, low offset? (Thirty-Nine)
Owner of the car is aallbbeerrtttttt
the wheels are 15x7.5 +0 offset wrapped in 195/50/15
Old May 18, 2007 | 11:01 AM
eL's Avatar
eL
How safe is it to ride on stretched tires? How does it affect your ride?
Old May 18, 2007 | 11:56 AM
Johnny.'s Avatar
Widow's Son
Pardon my ignorance, but what is "stretched" tires?? I've seen this a lot and still don't know what it is exactly.
Old May 18, 2007 | 01:34 PM
Milano Sol's Avatar
Default Re: (JohnnyG35)
its pretty much just running a smaller tire than recommended for the rim width, thus causing the tire to look (and it is) stretched to fit the rim. for a 7.5 width rim you could probably run a 225~235.....so running a 195 would stretch the tire on that width.
make sense
Old May 18, 2007 | 02:22 PM
eL's Avatar
eL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyG35 &raquo;</TD></TR><TR><TD CLASS="quote">Pardon my ignorance, but what is "stretched" tires?? I've seen this a lot and still don't know what it is exactly.</TD></TR></TABLE>
n00b
Old May 18, 2007 | 02:41 PM
Johnny.'s Avatar
Widow's Son
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">
n00b </TD></TR></TABLE>
Error
You are not authorized to edit Moderators or Administrators.
» Go Back
DAMET!!!
Old May 18, 2007 | 03:08 PM
eL's Avatar
eL
Error
You are n00b.
» Go Back
DAMET!!! </TD></TR></TABLE>
Fixed
