Looking for opinions....Skunk2 intake manifold special colors
We did a test on powdercoating Skunk2 manifolds to give people a little different taste.
We just finished one and wanted to see what you guys thought. All opinions are welcomed.
The powdercoating can hold up to 300 degree F.
Guest
Posts: n/a
hmm, yea.. you can get a heat gun/thermo gun or whatever,, do some before and after, run the engine on a dyno for 20mins, take 5-6 readings from the manifold, then swap the skunk on, do the same, see what happens..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpooledT3 »</TD></TR><TR><TD CLASS="quote">that looks really good.what colors can you guys do?</TD></TR></TABLE>
We can do basically any color you guys would like.
I knew that the topic would come up if the heat will dissiapate or not. We will put it to the test soon.
If this is a heat coating then I just think it would work. If it was like spray paint then sure. All the heat that the aluminum should disapate will be trapped in there heating up all the air coming in.
existanzcivicb20
Mar 22, 2006 06:15 AM
spoonsports12
Oct 12, 2005 09:53 AM
