Suspension & Brakes Theory, alignment, spring rates....
Suspension for AutoX/DD on EF hatchy
Old Mar 29, 2007 | 09:49 AM
B6tizzleHatch's Avatar
Default Suspension for AutoX/DD on EF hatchy
Long story short im buying my buddies ef hatch shell and going to make it my AutoX/Daily. On my hatch that I currently own I have Tokico Illuminas with S2 coilovers. That combo does very well for AutoX and not to shabby for daily driving. I guess im just kinda open to other ideas and would like to hear someother ppls opinion on what I should get the 2nd time around.
The reason I really like the Illuminas is because their adjustable, Ive heard many good things about Koni yellows but hae never owned them nor anyoneelse around here owned them that I know of.
Shoot me some Good Ideas and combos for Daily/autoX
Thanks in advance.
PS
I searched but theres a ga-zillion thread on suspension and I read through a few and they werent exactly asking the same thing I was.
Old Mar 29, 2007 | 09:53 AM
FalkenSiR's Avatar
Default Re: Suspension for AutoX/DD on EF hatchy (B6tizzleHatch)
for comfort you should focus on lower spring rates and adjustable shocks + bigger sway bars.
Old Mar 29, 2007 | 11:23 AM
Default Re: Suspension for AutoX/DD on EF hatchy (FalkenSiR)
Lowering springs are to soft for autoX IMO
It doesnt have to ride like a BMW or nothing close.
I just want it to handle really good, and ride decent. Just not crazy bumpy
EDIT: Anyone have experience with these?
http://www.jhpusa.com/catalog/...20d8b
Modified by B6tizzleHatch at 12:49 PM 3/29/2007
Old Mar 29, 2007 | 08:25 PM
Anyone?
Anyone used these in the past?
Old Mar 30, 2007 | 09:52 AM
hybridmoments's Avatar
wouldn't waste your money on Function and Form, D2, ksport, etc
they are all the same thing, and seem not to last long from alot of recent posts about them leaking/blowing.
for about the same price you can get this setup with custom spring rates of your choice
http://www.redshiftmotorsports...ustom
Old Mar 30, 2007 | 10:56 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Suspension for AutoX/DD on EF hatchy (hybridmoments)
Just go auto-x the car. Once your good enough, it will tell you what it needs...
PS: Tires are always the #1 suspension upgrade anyways...
Old Mar 30, 2007 | 12:25 PM
Default Re: Suspension for AutoX/DD on EF hatchy (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Just go auto-x the car. Once your good enough, it will tell you what it needs...
PS: Tires are always the #1 suspension upgrade anyways...</TD></TR></TABLE>
This is my 2nd yr AutoXing. Im no n00b to this.
Just wanted some other opinions to which you guys run on your cars for similar applications
Old Mar 30, 2007 | 12:57 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmoments &raquo;</TD></TR><TR><TD CLASS="quote">wouldn't waste your money on Function and Form, D2, ksport, etc
http://www.redshiftmotorsports...ustom</TD></TR></TABLE>
While that is the setup I run (and purchased from redshift as well), since the OP already has Illuminas, he might be perfectly content to just get a set of Ground Control springs with custom rates, and see how it fares. No reason to swap out a perfectly good set of shocks, until the driver is ready to start dropping serious cash for that last 2% (or whatever the difference would really be between Illuminas and Konis, or even if they truely are faster).
Old Mar 30, 2007 | 03:43 PM
Default Re: Suspension for AutoX/DD on EF hatchy (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">While that is the setup I run (and purchased from redshift as well), since the OP already has Illuminas, he might be perfectly content to just get a set of Ground Control springs with custom rates, and see how it fares. No reason to swap out a perfectly good set of shocks, until the driver is ready to start dropping serious cash for that last 2% (or whatever the difference would really be between Illuminas and Konis, or even if they truely are faster).</TD></TR></TABLE>
True, I just have a little problem. The shell Im buying has no suspension, So I need something to put on my current hatchy and put my tokico/s2 on the othere hatchy im buying
BlockMaster3K
Suspension & Brakes
Dec 28, 2018 10:52 PM
Chronicsinners
12
Jul 23, 2006 05:36 AM
TurtleEF3
Suspension & Brakes
10
Sep 5, 2005 09:55 PM
The Alchemist...
Suspension & Brakes
Jul 15, 2005 03:44 PM
jdmjunky
Oct 7, 2003 02:01 PM
